Asbestos removal testing/removal? - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » Asbestos removal testing/removal?
Old 11-07-2014, 07:57 AM
.......People get sick from asbestos after long term extensive exposure not a little bit here and there. ...
And how many here were doing their own drum brake shoe replacements back when asbestos was still being used in those products? IIRC, blowing out the old dust from the drum was part of the process.
Old 11-07-2014, 07:59 AM
People are still blowing out brake pad dust into a giant cloud and standing in it. Forget the now removed rock wool there is all kinds of stuff you don't want in your air bags in modern pads.
Old 11-07-2014, 09:40 AM
This. It is not plutonium. I use a garden sprayer to wet the work area and then run a sharp edged long handle tool under them to remove. Don't make the dust in the first place by working it wet. Mop/wetvac things up and your rock wool goes down the drain not all over your house. Black mastic often called cutback does have some fibers in it but very little and there are solvents that can be mopped down to soften it. There are also tile mastics that say they can be troweled over old cutback. I have installed tile over old cutback and also did the full removal thing. Both worked. YMMV.
Besides I learned from the whole foods/mother earth gang that It can't be bad for you if it is an all natural product.
What he said. Also remember:
Risk of lung cancer from asbestos exposure in non-smokers is less than no asbestos exposure in smokers. The real problem is asbestos exposure when your "mucocilliary clearance system" is paralyzed from smoking cigarettes.
If you want a respirator and don't want to fork out for a one-time use (they are not particularly expensive, though), I live close to you and you can borrow mine. PM me.
Old 11-07-2014, 09:52 AM
Rick K's Avatar
Rick K Rick K is offline
Rick K
The tiles are usually considered non-friable them you remove it with scrapers, etc. No grinders or saws allowed. You don't need a special asbestos abatement company for the tiles. You may want to sample/ test the mastic as well. If that has asbestos you may need to pony up some $$ to have a certified company do the removal.
This. Just went through all of this in our "new" house basement. The adhesive didn't have asbestos, tiles did. I hosed down the tiles with water and dish soap and scraped them up.
1985.1 944 - Brown
98 M3 - Silver
84 RoW Coupe - Guards Red
86 911 - Black
95 993 - Silver
80SC - Hellblau
73.5T - Sepia
Old 11-07-2014, 10:36 AM
An effective respirator is one that has been properly fit to your face. Anything less and you are fooling yourself if you truly deal with friable asbestos.
Old 11-07-2014, 10:44 AM
This is true, but not all that difficult. Rule one is NO Facial Hair! Next a negative pressure test: Cover the inlets for the filter cartridges and inhale. If there is leakage, the mask does not fit. This test should be performed every time a mask is donned. Use the proper cartridges for the known hazard, and replace per manufacturer's specifications.
Old 11-12-2014, 07:46 PM
88carrera's Avatar
88carrera 88carrera is offline
88carrera
Thanks everyone,
Hopefully its just the tiles and not cutback. If the cutback contains asbestos I don't want to mess with it and would rather put mastic right over it. Peter I will pm you after I close on the house.
Howard
2003 996TT
1993 Mini Cooper
(SOLD) 1974 Datsun 260z, 1997 911, 1988 911
