Yeah, so were mine. And one front wheel bearing loosened on Friday. And the left front loosened at the August event. And at an event last season one of the rears was slightly loose. All were due to the bearing replacement work done by the shop not being quite perfect -- and they are a good shop. It happens, and is very easy to check for.
i wish that i could make this happen at low speed David that would make my life easier. Unfortunately it will only occur after heavy use on track.. never ever on the street
Gotcha. I was just throwing that out there as something that could be happening in addition to the main problem since it seemed the pedal normally 'drops' a little.
BTW, do you have any brake cooling other than factory scoops? Are you running stock wheels? Are the wheel spokes sufficiently open for good expose of the caliper? Have you removed the sheet metal dust shields on the insides of the rotors?
#16
I suspected MC problem, but also bearings (had that happen) pushed and pulled on all wheels, no movement. Agree vacuum would just give a hard to push pedal but not a long pedal. There was no loss of fluid from reservoir or evidence of leaks. There was no fade as such as pedal did not go down slowly but just went right down, bled several times and no bubbles. Mike did a good job handling the issue, I heard "BRAKES" no panic from either of us coming into T10, he did miss the apex though!!!
Dirk
Safety Chair, PCA Potomac Region Retired DE Chair, PCA Potomac Region. Retired Co-Chief Instructor PCA Potomac 2008-2012 1971 914/6 (Factory) 3.2 Track car 1988 911 Targa 1986 944 Last edited by Chopper Dropper; 10-27-2014 at 05:41 PM. Reason: more info |
#17
well the MC and booster and a seal kit are on their way - time will tell
#18
old fluid stuck in ABS module? Just throwing it out there. But frequent flushing of the system might be slowly purging out the bad fluid?
Is this a two driver car? is the second driver experiencing similar issues or is it the driving style of one of the drovers? Maybe the MC is the issue. Rebuilding/replacing a potentially 15 year old component may not be a bad idea.
#19
Did you go GT3 MC ?
Scott Bresnahan Purcellville Va. 2014 GTB1 World Champion 8 Time National DE champion 88 911 Cup 2021 GT4 13 Boxster S 1969 Saab Sonett 2013 Cayenne 2014 F150 Hurricane race trailer with A/C 05 Cup car 02 Koni 996 |
#20
did not - yet. $100 vs $550 was a no brainer given that i dont know its the right issue
