996-C2 (1999) Brake Issues - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » 996-C2 (1999) Brake Issues
Prev Previous Post   Next Post Next
Old 10-27-2014, 04:52 PM
1. Not that it likely is the issue, but a small amount of pedal movement before the brakes engage usually means you should check the wheel bearings to see if one (or more) is loose.
2. Do you really name your cars?
