MIG welding wire feed issues - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Other Technical Discussions » MIG welding wire feed issues
Prev Previous Post   Next Post Next
Old 07-06-2014, 10:45 AM
scotty b's Avatar
scotty b scotty b is offline
scotty b
I've got a MM-180 for my regular use and run .023. (.045 in the M-250 for heavier stuff ) the best way to setup the rollers is to pull the trigger and let the wire run into a solid object, ( ie: the floor, and piece of lumber etc ) and tighten the rollers until it starts to drag from the pressure, right before it starts to bind. Then back off 1/4 turn. This should be close to the best amount of tension to feed properly and not birdnest, and the extra 1/4 back will give you a touch of wiggle room in case your liner kinks, spatter build up, or worst case a glob of molten metal gets on the tip and closes it off
