A friend and I are going to swap out my 915 transmission for another one - for my 1984 Targa. I have been around most of one and part of another swap but they were years ago and I can't say I remember everything very well. I have the Bentley manual (in black and white) and my friend is a very good amateur mechanic - but doesn't have any experience with Porsches. So wish us luck!
We will be doing the work in a second garage behind his house and he suggested I do more homework to put together a list of things to do while the engine and transmission are out. We don't have a deadline. Any suggestions?
Chip 1984 Targa |
Off the top of my head:
- Clutch - Oil seals on the oil cooler and thermostat - Cylinder head temp sender
Idiot light sender next to thermostat.
While its out:
- replace the spark plugs - do a valve adjustment - check for any broken head studs - inspect axles & cv boots, replace/rebuild as necessary - inspect engine & transmission mounts, replace as necessary, or upgrade to wevo It's quicker/easier to do all of these with engine out, so you might as well. Since its a 915, you can also take the opportunity to upgrade to the brass shift coupling bushings.
Thanks for the suggestions!
Chip 1984 Targa |
Check the heater hoses and cables.
ftfyb-o,
Bill Miller lives in Darnestown. Swapping transmission is a breeze for him. Perhaps you could contact him and ask for "advice" - he's great, and close.
