I merely stated that the sealant that the RV store sells as vibaration resistant is likely a marked up version of the HD stuff. There is nothing about my purchase intent.
Nader There are 3 sides to every story. Mine, yours, and the truth. 91 944 S2 - Mine, Sold 7? 914-6 Vintage racer - Mine 93 964 - Not mine 95 993 - Hers - Sold and will be missed 04 GT3 - ours? Doing double duties at DE, anyway 06 987 - Hers - plan to let son use for DE - My DIY A few others |
You guys have your heads up your butts with this 'designed for vibration' nonsense.
Any good urethane or silicone sealant is designed to accomodate cyclical movement. Class 25 accomodates 25% joint movement, Class 50 accomodates 50%, etc. Stuff made for roofs of RVs are typically membranes and not joint sealants. The talk of RV roofs just confuses the issue. As Dr. K would say, sheesh...
Marine clean is the best prep cleaner I ever ran across. You could also use great stuff expanding foam to fill any voids,trim up and do a final cover up with a paint-able silicone.
tape the seam with helicopter tape and be done with it.
http://www.amazon.com/ISC-Racerstape.../dp/B000TPC7HU
