996 tiptronic transmission fluid change - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » 996 tiptronic transmission fluid change
Old 01-09-2013, 10:32 AM
Elfer's Avatar
Elfer Elfer is offline
Elfer
Default 996 tiptronic transmission fluid change
Getting close to 90K. Should I just drain and change the fluid, or change the gasket and filter too? It looks a little complicated doing the whole filter/gasket pan removal...
http://www.renntech.org/forums/tutor...ssion-service/
Everyday | Driven
everydaydriven.com
02 Coupe
83 Esprit Turbo
Old 01-09-2013, 10:57 AM
Do the filter. The 5HP19 has known weaknesses. Filling the fluid is a PITA already so I wouldn't skimp on the filter. Its not complicated, just messier and a little more time consuming.
Given their fragile nature I wouldn't use the penzoil listed in the renntech article either. I'd go for one of the approved full synthetics. Sure its pricey (fwiw, the identical vw/audi stuff is cheaper than the porsche labeled bottles) but its not like you do it every 5k miles.
IMO, after replacing the wife's boxster tip TWICE and reading up on the 5HP19 to great detail, I think people should be doing their ATF far more often then recommended.
Edit: Whatever you do, do NOT turn the engine off before putting the fill plug back in
1984 930 - 3.6L
Old 01-09-2013, 11:10 AM
Elfer's Avatar
Elfer
The 5HP19 is the ZF? I thought my '02 tiptronic was the Daimler Chrysler one and not the ZF?
Everyday | Driven
everydaydriven.com
02 Coupe
83 Esprit Turbo
Old 01-09-2013, 11:16 AM
Elfer's Avatar
Elfer
http://books.google.com/books?id=Raa...ic%20s&f=false
according to the 996 book ...
Everyday | Driven
everydaydriven.com
02 Coupe
83 Esprit Turbo
Old 01-09-2013, 12:21 PM
^ Thanks, added book to b-day list! BTW what's deal with your avitar? Looks like the tarka top is coming off?
Old 01-09-2013, 12:28 PM
Tito
86911TLCAB
do these havea torque convertor?
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
Old 01-09-2013, 01:32 PM
I was unaware they was anything other than the ZF. My wife's was an '01 box and it was also used in the 996. But Daves link clearly shows a daimler unit was also used on some models. Learn something everyday. You're going to need to know which one you really have
1984 930 - 3.6L
Old 01-09-2013, 04:42 PM
Elfer's Avatar
Elfer
I found a pic of an 80's maxwell tape poster and just cropped it...
Everyday | Driven
everydaydriven.com
02 Coupe
83 Esprit Turbo
Old 01-10-2013, 09:25 AM
Tito
86911TLCAB
i recently did the gasket/filter on my jeep...was actually quite a simple procedure...
the issue for me with the automatics was how to change the fluid int he torque convertor without the machine which pushes fluid up through the convertor and the cooler...since i had to pull the tranny anyways to swap a seal, wasnt an issue as the TC had to come out anyways...
I need to do the same to my e30(though dont plan to pull the tranny)...i saw a youtube video where one does the filter/gasket and refill the sump, then run the car with one of the cooler connections running to a bucket and filling the sump at the same time, until the clean fluid came out...anyone done this?
do the tiptronics have a torque convertor?
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 01-10-2013, 09:37 AM
All automatics have a torque converter. (incl tiptronics.)
Newer electronically controlled transmissions like SMG & PDK are really manual transmissions w/ the shifter and clutch 'simply' being controlled by motors being run by a computer. Those don't have torque converters but real clutches just like a manual (because thats what the transmission really is.)
1984 930 - 3.6L
