Tire Experts: is my tire dead??? - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Tire Experts: is my tire dead???
Old 06-08-2012, 10:58 AM
ausgeflippt951's Avatar
Shock Whisperer
Default Tire Experts: is my tire dead???
Ok so to those paying super-close attention, I mentioned in the Shenandoah DE thread that I found a potentially life-ending issue with my Right-Front tire whilst inspecting them at the end of the DE last weekend.
There appears to be a "crack" forming on the corner of tire that has spread to the tread.
A little history: the crack has actually been there for some time, but has only been limited to the very "corner" of the tire (i.e., where the tread and sidewall meet) and was no more than 1" long. I had it inspected by Discount Tire out in AZ (some friends of mine worked there) and was given the OK to use. Since this inspection, I've run these tires for about 8 DE days without issue.
The maximum crack depth (which is also at the corner) is slightly more than 1/4", but is at a ~30deg angle, meaning the total depth (perpendicular to surface) is only a few mm.
However, it appears as though the crack has spread?? It's possible the crack has been there all along; it actually continues VERY FAINTLY about 6" down the tread. The part of the crack that is on the tread is <3/32" deep, maximum. Average depth is probably 1/16".
Thanks in advance! I'd really like to be able to milk every last drop out of these suckers...
Collin M.
I wear a cowboy hat.
'06 M3: hers.
Old 06-08-2012, 11:06 AM
Is that a bear eating the arm off a naked woman on your ring?
1984 930 - 3.6L
Old 06-08-2012, 11:08 AM
BMAN's Avatar
BMAN BMAN is offline
Cushion Convector
BMAN
off a naked woman
deleted
_______
Brian
'71 T
'72 E
'80 Weissach SC
'94 C2
'05 996 GT3 CUP
'11 GTS/C4S Donuts
'15 Boxster S #Blubyu
Old 06-08-2012, 11:13 AM
I think you have
Old 06-08-2012, 11:25 AM
pjalexandre's Avatar
pjalexandre pjalexandre is offline
pjalexandre
For your safety and that of others. Do not run that tire anymore.
-Paul
Old 06-08-2012, 11:41 AM
X2 on its probably done, and should be replaced. IIRC you mentioned in another thread that these tires had some age on them. As the rubber ages, it gets harder and more brittle, thus prone to cracking. The crack is now becoming a potential "break away" point for some tread to chuck off, particularly if you're forced into an off-pavement excursion, and catch the pavement/curbing edge just right. Plus I believe that crack is deep enough that moisture is now able to get into the cords, and the steel belts can begin rusting, leading to further delamination under the tread.
IMHO, better safe than sorry. Would be a pain for a $200 tire to cause you to miss part of a DE weekend or damage the car due to luck not stretching out as long as you'd hoped.
Old 06-08-2012, 12:17 PM
...or injure somebody else
What size is it? I have some mostly-used-up RA-1s in my garage that probably match the rest of your tires. PM me if it's 225/16 or 245/16. cheap or free depending on tread.
Ha ha - he has a BEAVER on his ring. Geeky brainy show-off...
Old 06-08-2012, 12:20 PM
gota say that is not an everyday ring...
Most of the folks that hang around here would say that tire is done. Water can get into the steel belting and cause it to fail.
Cliff Claven Cliff Claven is offline
Cliff Claven
if you want to keep milking it you probably need to look into retreading it
