I'm planning on replacing the pop-off in the air box, and am wondering if there's a "better than others" epoxy out there that I should use. I've tried the Loc-Tite epoxy kit, and it's crap.
Thanks!
Rob T. 2006 Carrera S 2013 Cayenne GTS |
I used JB Weld for the pop off valve, worked for years now.
Okay - thanks!
Rob:
Another alternative. Years ago I got a two part epoxy for repairing soft bumper skins and I've used it for a bunch of other things. It dries into a hard but somewhat pliable plastic that has good adhesion properties -- gray in color. I got it at AutoZone.
Greg Rockville MD |
Thanks, Greg. I'll take a look.
3M structural adhesive, never look back
never enough money...never enough time...nothing ever fits 82SC, Lanna 02 C240, Das-Uber-Lux-O-Cruiser 97 Boxter, She named it Willy 86 Dodge 4X4, Peggy, The Arctic Warrior Go Army |
why you might see a pop off valve bouncing along in the street?
another vote for the slow set JB Weld.
Never had a problem with the stuff.
Now I say that there's a joke son....
At marine stores is 2 part epoxy FlexSet. It's expecially good at joining dissimiliar parts that would tend to seperate due to cold/heat cycling different expansion/contractions. It was the only product I'd trust with upgrading my 1977 air deflectors to the Carrara plastic one piece where I had to adapt 2 plastic sliders glued under the sliding roof.
anything that takes a solid set on these pop off valves is at risk imho http://www.marinetex.com/marinetexflexset.html
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x 6 |
