DIY fail - Dorkiphus.net
Old 10-17-2010, 08:51 PM
Default DIY fail
The reverse lights on the 996 have been non-functional for a while, and today I decided to tackle the problem.
Fluke multimeter in hand, I opened up the tail lamps and checked the bulbs. Both bulbs are good. Next I checked for voltage at the sockets while the car is in reverse. No voltage.
Next, back the car onto some ramps and crawl underneath to find the reverse switch on the transmission. Car sits so low to the ground, that even on ramps, my nose is touching the underside of the car. Tight sqeeze, but I crawl over to the gearbox. Of course there are a dozen little torx screws that hold the plastic panels to the underside. Crawl back out, clean the dirt off my nose and face, grab the torx drivers and crawl back under.
After a few contortions, I get all the screws out and remove the panel. Of course I get a face full of sand and gravel as I'm moving the panel out of the way. Now to find that pesky reverse switch.
Found it, front right corner of the gearbox. I unplugged the connector and checked for voltage at the terminals. Got voltage at the connector! Hmmm lets remove the switch and test that. Looks like about a 17mm? Crawl out from under the car, clean off my face, grab the 17mm wrench and stuff myself back under. Shit. It's a 19mm. Crawl back out, grab the 19mm, crawl back under. Remove the switch, crawl back out, and test it with the multimeter. Hmm, switch seems to work just fine.
Maybe it's a gearbox problem, and the part inside the gearbox isn't pushing the switch? Crawl back out, get a pencil, get a helper, and crawl back under. Put the pencil into the transmission switch hole, then have the helper shift into reverse. Pencil pushes up. Ok, so that's working. WTF else could it be??
Maybe the connection to the switch is loose or dirty or something? Put the car in reverse, crawl back under, and try pushing the reverse switch with my fingers, while a helper watches the lights. No lights.
All the components are good, why the heck aren't the lights working?? Now I'm 2 hours into it, pissed off that I can't figure this out. As I'm sitting there considering just taking the car to a shop, to let them sort it out, I remember the 996 has an absurd number of fuses in the fuse box. There can't possibly be a fuse, just for the reverse lights? Can there?
There is. And it was blown. Changed the fuse and everything works.
Old 10-17-2010, 09:02 PM
tdatk's Avatar
tdatk tdatk is offline
Moonshine Tester
tdatk has one HoF thread
It's always the last place you look....
Tim
05 Cayenne TT
03 M3 (sold)
82 911 SC (sold missed)
90 C2 (sold missed)
87 928 S4 (sold)
85.5 9 fofo (sold )
Old 10-17-2010, 09:47 PM
fuse.... go figure
Old 10-17-2010, 10:07 PM
Ah, but why did it blow?
Old 10-17-2010, 10:20 PM
tdatk's Avatar
Moonshine Tester
Antifreeze........
Tim
05 Cayenne TT
03 M3 (sold)
90 C2 (sold missed)
87 928 S4 (sold)
85.5 9 fofo (sold )
Old 10-17-2010, 10:22 PM
TurboPooch's Avatar
Now known as Robbie's dad
TurboPooch
^^^+1 I'd check to see what else is on that circuit. If nothing, I'd replace both bulbs or at least check them carefully.
89 944 Turbo Race car
98 993 C2S w/Aerokit II
70 Boss 302
86 Mustang SVO
24 F250 SD Godzilla
Old 10-17-2010, 10:44 PM
Who knows. This car has more wiring than the internet. The reverse lights are also tied into the power seats, power mirrors, and alarm system, all of which were misbehaving. Replaced the reverse light fuse, now all those other things are working perfectly too. Those other things also have their own fuses.
Old 10-18-2010, 08:18 AM
George, I cannot believe you admitted that the other things on the same fuse were misbehaving. We all know you just wanted a black spot in the middle of your nose and this was the excuse (going as a puppy for Halloween?). Sheesh!
Old 10-18-2010, 08:40 AM
arob's Avatar
arob arob is offline
Don't believe the hype
arob
Don't worry George. It would have taken me at least two hours to replace the fuse alone.
Rob T.
2006 Carrera S
2013 Cayenne GTS
Old 10-18-2010, 10:24 AM
Well now you know that much more about your car. consider it a learning experience. I have had many of them at least your adventure did not involve power tools and blood loss.
