#831
Steel lug nuts do a good job too if it's not too fubar'd.
#832
X2, go slow use some pemitraing oil as you turn nut. Slow 1/2 - 3/4 turn down, 1/4 + turn back (just like using a tap), repeat, and repeat. You've seen me do this many times
#833
This is worse that TR's that I've seen "repaired." I have found the proper tool locally and will use later today, giving me time to order studs if it doesn't work, but like the posts above, I believe this will be easily fixed with a little patience and the correct tool.
#834
FIXED! Getting the car and tool in the same place was 100X as hard as (1) spraying oil on the stud, (2) running the tool up the stud (3) testing a lug nut went on smoothly, and (4) cleaning out the tool with Brakleen.
#835
-Fritz '93 C2 Cabriolet - That cool Amazon Blue-Green Metallic color '70 911T, sorta - '70 Chasis, '77 shortnose, 3.0L CIS engine, and SC fenders |
#836
Believe it or not Dr's get time off too
#837
Actually, today is a "DrFirst" day, and I ate lunch during a meeting, then did 2 1-hour conference calls while completing my "errand" so I'm actually working EXTRA today! Put my phone on mute so they wouldn't hear the grunting and cursing...
#838
If they had, they would have just assumed you were doing an office visit...
#839
My patients do not grunt or curse when they're with me!
#840
cause the drugs are that good? or is it because you trim your nails
