Dr K's Project Car - Page 82 - Dorkiphus.net
Old 09-23-2010, 07:14 PM
ROTFL! Id reverse the latter directions though, else you might not be able to screw the sensor all the way in.
Shows you that a little info is worse than none. I like to set the bung stand off so the sensor threads don't protrude into the tube. After drilling the hole if the sensor hits the tube rim a little you can run a tap to clear the path. This ends up with less of a gap that seems to build up carbon and help jam the sensor in the bung. This also lets you weld bungs in places you might want to use later while building a pipe up and only need to drill it out if needed.
Old 09-24-2010, 11:41 PM
Got a question: After removing the GHL headers, I held up the new old-style headers for hit. On the driver's side, where the header goes forward and folds upward a bit, it hits a piece of sheet metal at the front of the engine. This specific piece seems separate from what goes around the engine and looks like it would just come off easily, but is there a specific purpose for this?
The real question is: should I take it off or cut away the part where the header would hit it? The sheet metal is marked by the arrow in the photo below.
Name:  Engine Tin small.jpg
Old 09-25-2010, 06:44 AM
Jose's Avatar
Jose Jose is offline
Jose
I just trimmed that piece to clear the header tubes.
Josh
'11 M3
Old 09-25-2010, 09:07 AM
blue tape to keep stuff from falling out of the motor?
Old 09-25-2010, 12:04 PM
KFJ's Avatar
KFJ KFJ is offline
Lemming
KFJ has one HoF thread
I LOL'd at that too. Maybe it's to keep the stinkbugs out???
Kirk J.
78 911 SC euro spec
05 Audi S4
01 Audi A6 - gone...
Things are made of stuff -Bill Nye
Old 09-25-2010, 11:08 PM
I'm pretty messy. Does everybody agree with Josh to cut the tin rather than remove that piece?
Old 09-25-2010, 11:33 PM
APKhaos's Avatar
APKhaos APKhaos is offline
APKhaos
Josh had exactly the same problem, solved it, and told you how he did it. That's the guy with both knowledge and experience. Now you want to throw it open to anyone with an opinion? Seriously Pete, are all your decisions made this way?
Tony K
PCA Potomac, Rennlist Member
89 944 Turbo
85 Carrera - Sold
TrackVision
944Cup
Old 09-26-2010, 12:34 AM
OldTee's Avatar
OldTee OldTee is offline
OldTee has one HoF thread
It is the way he backs into things!
ARF
OldTee
Sold 79 911SC
1991 Corvette
Capital One is the pits!
Old 09-26-2010, 08:04 AM
I know Josh has skills, but there are often several ways to skin a cat, and often reasons for doing one way over another--sometimes one will last longer or reduce future problems that I couldn't begin to think of but others on this board could. I was just hoping for some confirmation before I started cutting (which is not reversible). Didn't mean to dis Josh.
Old 09-26-2010, 08:56 AM
Sounds like Drk needs to start an" i'm sorry Josh" thread
