944 coolant temp - Page 2 - Dorkiphus.net
Old 06-03-2010, 04:53 PM
Originally Posted by pnbell View Post
there is no Danger Zone
Blasphemy! Kenny Loggins says otherwise.
Old 06-03-2010, 05:24 PM
John Clay's Avatar
John Clay
I was thinking of adding WW to my coolant? Though I hear mist people running g only We and distilled. Any thoughts on just adding to 50/50 coolant?
WW = Water Wetter
mist = most
g = ???
We = ???
I need help on the last two.
Water Wetter added to 50/50 coolant seemed to help a bit on temps in my fo fo. I recall the manufacturer saying it was more effective with straight watter.
John Clay
2011 Cayman
1986 944 "Traffic Cone"
2013 Scion FR-S
Old 06-03-2010, 05:39 PM
pnbell's Avatar
pnbell pnbell is offline
pnbell
Ha ha... I apologize, I am typing on my Droid. Sometimes it decides to write what it wants too...
But really You did a great job decoding my encrypted Droid language.
"G" is nothing..
"We" was supposed to be WW, but my phone "fixed?" it.
OK anyway. I might try some WW then. Really I am only concerned because it is affecting my oil temp and pressure.
Old 06-03-2010, 08:45 PM
racer's Avatar
racer racer is offline
racer
What year is your 944? how many miles? Did you install an oil temp gauge? I know my '87 has water temp and oil pressure
Clarks garage indicates oil pressure at idle should be between 2-3. Only worry if closer to 1. So.. where is yours approx?
- 1970 914-6
- 2000 Boxster
- 1987 944
- 1987 924S
- 1978 911 Euro SC
- 1976 914 2.0
- 1970 914 1.7 / 2056cc
Old 06-03-2010, 09:32 PM
John should have known that by the lack of a signature.
I have been thinking about cooling on my 944. The front plate actually covers some of the effective cooling of the radiator. I think. I've been thinking of removing it for the track, I have seen the effects a blocked/covered radiator has on the "oval" tracks. Maybe I should actually add some tape for more downforce....damn, my red neck is showing.
In all seriousness, I wonder what the added benefit might be.
Old 06-03-2010, 10:40 PM
racer's Avatar
racer
Take the plate off, Steve, it WILL run cooler.
- 1970 914-6
- 2000 Boxster
- 1987 944
- 1987 924S
- 1978 911 Euro SC
- 1976 914 2.0
Old 06-03-2010, 11:18 PM
That's it? You don't have water pressure? Water pressure gauge is particularly important if you track your car.
Old 06-04-2010, 07:38 AM
jerome951
When the car gets warm, are both fans coming on high or just the single fan at low speed?
For wiring a manual switch, all you have to do is complete the ground circuit at the temp switch at the rad or at the relay (at least in my turbo). I'm not using a fuse on either line (I have both the low speed and hi-speed switched via separate switches) and haven't had a problem.
Jerome Welte
'97 Spec Boxster
'20 Nissan Titan XD
'02 BMW 330i convertible
Old 06-04-2010, 11:10 AM
pnbell's Avatar
pnbell
Since my signature is missing: 87' 944na, 175k and rising, daily driver.
No after market gauges just yet.. As time goes on, I would like to add gauges and switches everywhere. So when I start my car it will be like starting a small airplane!
-remove the key style ignition, and replace it with a ridiculous amount of stainless steel toggle switches! Ha ha
"Fuel pump. Check. Oil pump. Check. Ignition. Check. Prepare for take off."
Old 07-07-2010, 12:30 PM
pnbell's Avatar
pnbell
To close this post in case someone searches "944 temp"
My water pump seized on Thursday, I replaced it over the weekend. Now the temp runs right in the middle all the time, even in traffic with the outside temperature over 100 degrees!
It appears my water pump was slowly failing, and was unable to keep my water temperature where it should have been.
When the pump seized it did destroy my timing belt, it did not break; but the belt was shredded pretty bad... 'phew'
