Valve Adjustment? - Page 4 - Dorkiphus.net
Old 11-30-2009, 07:23 PM
signifyingmonkey's Avatar
signifyingmonkey signifyingmonkey is offline
signifyingmonkey
Could this be the problem?
I don't know what happened to the end of the cable.
Old 11-30-2009, 07:46 PM
signifyingmonkey
It doesn't look like the pic uploaded. The cable that attaches to the throttle has no end.
Could this cause the no start problem?
Old 11-30-2009, 08:36 PM
does anything move when you push the gas pedal? Thinking on this even if the cable were off the csar should cough or fart some at least. Did you try some starter fluid yet?
Old 12-07-2009, 05:35 PM
signifyingmonkey
The valves were too tight!
I spent my Friday night readjusting the valves. The car runs, but under 2500 it runs rough. The idle is at 800-900.
I will check the plugs first. What else should I check?
Old 12-07-2009, 05:41 PM
You're joking I hope. If the valves were adjusted so tight that it would cause a no-start condition, you did something *seriously* wrong during the adjustment. I hope something wasn't damaged in the process.
Check the plug wires for the rough running. Unless something got damaged, or is *severely* out of adjustment, it will not cause rough running below 2500 rpm as you describe.
Old 12-07-2009, 06:42 PM
signifyingmonkey
Unfortunately, I am not joking.
What should I check for possible damage?
Old 12-07-2009, 06:57 PM
chris prack chris prack is offline
chris prack
I was certain that was the case. You need to do a leakdown test on the engine.
Chris Prack
89 944S2
89 951
84 944
Old 12-07-2009, 07:19 PM
OldTee's Avatar
OldTee OldTee is offline
OldTee has one HoF thread
I have been gone and lost track of what is going on. Somebody needs to go over and spend an hour or two with this new Dorki and see what is going on before something bad happens. I live closer to the high water mark of the Confederate States of American than I do to South Riding, VA. The cable sounds like the speed control.
ARF
OldTee
Sold 79 911SC
1991 Corvette
Capital One is the pits!
Old 12-07-2009, 07:29 PM
chris prack
ARF
This could be arranged.
Chris Prack
89 944S2
89 951
84 944
Old 12-07-2009, 07:52 PM
Wow! Thats a new one. As chris said leak down test time and if it were my motor i would not run it another second until i checked the condition of the valves.
