PCA's Rules Changes for 2010 - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Track Talk » PCA's Rules Changes for 2010
Old 11-10-2009, 10:34 PM
MBuck951 MBuck951 is offline
MBuck951
Already have the plates and am underweight as it is. Easy winter for me =)
Mike
'88 951 "S" - 944 SuperCup/SP3 #744
'08 Tundra DC SR5 4x4 5.7L
'03 IS300 5MT
Old 11-11-2009, 07:47 AM
forklift's Avatar
forklift forklift is offline
forklift
Get effin serious about racing Peter or don't bother. 11lbs is the difference between winning or losing. I am so weight conscious that when I realized I forgot to remove the Curry's gift card out of my pocket at the beginning of the PCA race i threw it out the window on the pace lap. Racing is serious biniss.
Yep....take out that 11 lbs x10 and you probably have a half second.
Jim, ex P-car: 93 RSA, G stock #222
Old 11-11-2009, 07:52 AM
The RS Carpet weighs 11 pounds. Is it really worth removing it and putting in all that work to get the glue off for 11 less pounds and lots less noise. My carpet is currently out, but I was planning on putting in RS Perlon rather than getting all the glue off.
I say paint over the glue, and the keep a couple of helium balloons taped to the roll cage to offset the weight of the paint.
Old 11-11-2009, 07:55 AM
forklift's Avatar
forklift
That's how Tippy Turtle got a refund from the usps.
Old 11-11-2009, 10:27 AM
It would be nice, for once, to get a serious answer. If I can get to weight by FG bumpers, removing excess wiring, sunroof, AC, soundproofing (a lot of cars in stock class seem to have weights), are there other reasons to remove RS carpet or not put it in? I have a busy enough winter planned already...
Old 11-11-2009, 10:32 AM
It will if the car catches on fire and you're still in it....
That explains where PK got his
Old 11-11-2009, 11:15 AM
N Fotouhi's Avatar
N Fotouhi
Man,
You are not just slow on the track. You have stripped the car for the cage. People tell you that you no longer need to put the carpet in and you b!tch that you are busy. How NOT putting the carpet back in the car is more work?
AFA weight goes, it is not just the weight, but how it is distributed. People remove bumpers and sun roof to take the weight from up high and then add balast down low to make weight without consideration that they would have made weight without using FG bumpers, etc. So, hopefully you cleaned the crap under the carpet before going to Piper. Just paint the inside, so it looks better than TR's interior and move on. Learning you will take a lot of time.
Old 11-11-2009, 11:18 AM
Originally Posted by N Fotouhi View Post
Man,
X2 (except for the dig at DOS COUP ). Putting weight back in low and centered seems like good advice to me!
Old 11-11-2009, 11:26 AM
N Fotouhi's Avatar
N Fotouhi
A/C compressor is the biggie for the 44 guys. Most 911 cheaters could simply discounnect the belt and not lose any power turning the compressor which was not possible in a water pumper. I am already looking for the A/C bracket and belt. I think some guys would got the compressor to loose weight and minimize power it took to turn the thing.
No camber plate for me at this point. I get -3 or -3.5 camber with the set up I have. When I submitted my comments for carpet delete, I also added that removal of other interior pieces such as lower rear seat bottoms should be allowed, but I guess that did not go. Maybe next year.
Old 11-11-2009, 11:30 AM
N Fotouhi's Avatar
N Fotouhi
I thought is was Das Coup and it was not a dig. Does Curry sell paint? May be you and I can go in and buy the good Dr.'s card. Either my interior will be brown or Das Coup's could match the bumpers depending on what is available.
