Adding lightness from the ground up - Page 37 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Adding lightness from the ground up
Old 10-06-2009, 09:14 PM
MLIN's Avatar
MLIN MLIN is offline
MLIN
amazing, Kurt. Glad things went so smoothly on its first outing.
Michael L
2004 C2 Cab
1990 C2 G/H class racer
1988 911 3.2 w/ a ducktail - Sold
1999 Boxster - Sold
Old 10-07-2009, 08:43 AM
BillJ's Avatar
BillJ BillJ is offline
BillJ
I want to see earlier - like pics of the original 77 tub. This was the earliest I could find:
Attachment 20469
I want to see the car when he first got it filled with debris. Love it. Actually - i cannot see enough pictures of this car.
2002 M5 (Sold)
2010 WRX Sedan (Sold)
2001 M3 Vert Alpine White/Black (Sold)
2002 996 (Sold)
1995 993 (Sold)
1973 914-6 (Sold)
Old 10-07-2009, 09:23 AM
The other thing that blows my mind about Kurt's "Holy Carp" is that he judiciously sent it out on it first outing with the suspension set about 2" ABOVE where it should be.....and it still turned 1:22's !!
Old 10-07-2009, 09:57 AM
so kurt.... what can you do w/ a banged up '73...??
Old 10-07-2009, 10:40 AM
You guys are so easily impressed. From the "before" picture to the "after" picture was just some welding and bolting parts on...
Old 10-07-2009, 12:11 PM
jerome951
Yeah, it's not like he even rebuilt an engine.
Jerome Welte
'97 Spec Boxster
'20 Nissan Titan XD
'02 BMW 330i convertible
Old 10-07-2009, 07:57 PM
MBuck951 MBuck951 is offline
MBuck951
Awesome Kurt. Glad the shakedown went well.
what is the plan for graphics?
Mike
'88 951 "S" - 944 SuperCup/SP3 #744
'08 Tundra DC SR5 4x4 5.7L
'03 IS300 5MT
Old 10-08-2009, 08:18 AM
Parenn911's Avatar
Loose Lips Sink Ships
Parenn911 has one HoF thread
Yep, and he didn't even have to put on a rubber glove!
Old 10-10-2009, 08:44 PM
During the first shake out weekend I found that the motor would fuel starve in some corners. I moved the pickup tube in the cell and it improved things but only a little and only if the tank were stuffed full. After 8 or 9 laps the fuel pickup would again uncover in high G corners. I purchased an inexpensive passive ATL surge tank with 3 ball check valves. (the kit was cheaper than the 3 valves as parts) ATL cells have an oval shaped bulkhead opening and the surge tank is a good bit larger than the hole in the non ATL cell I have. Ship in a bottle time. I cut slot in the plastic tank making the tank into a C shape of sorts. After cutting and bending a strip of aluminum I riveted it to the cut out strip. I dry fit the cut back into the slot in the surge tank and then drilled and dry fit the rest of the rivets. Took it back part and stuffed it through the hole and into the cell. Working inside the tank with one hand I riveted it together and then reinstalled the valves and fittings. Fitted then snugged up up the fuel hose with a Otecker clamp. I took some measurements and bent a curve in a thin strip of steel to pin the tank in place. It runs between the bottom of the surge tank and the metal internal bulkhead ring (red arrow) There are ribs in the cell wall and the surge tank sits right in between them. After replacing the foam blocks so they make flow channels to the check valves the cell went back in the car. Hopefully I can get more than 8 laps before refueling.
Old 10-10-2009, 11:00 PM
87turbolook911's Avatar
87turbolook911
Very clever Kurt!
Vu
