orientation of front bilstein housings - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » orientation of front bilstein housings
Old 03-16-2005, 02:09 PM
Default orientation of front bilstein housings
Is the insert in the Bilstein strut in the "upside down" position?
How about the rear?
Old 03-16-2005, 02:58 PM
OldTee's Avatar
OldTee OldTee is offline
OldTee has one HoF thread
counterintuitive. Screw end to the top on both. Front has a hole for the bottom. Be sure to clean out the old rubber completely. Rear takes a bolt in the bottom. On mine the fronts were inserts. The rears were shocks. Take the old ones to Hersheys. Somebody may actually buy them.
OldTee
Sold 79 911SC
1991 Corvette
Capital One is the pits!
Old 03-16-2005, 10:58 PM
Strut inserts for Bilstein assemblies go in "upside down" and secure with a roll pin at the bottom. Bilstien inserts for Boge assemblies go in the traditional way. For rears you replace the whole assemblies, and they all look the same (Bilstien, Boge, Koni). Impossible to mess up in the rear.
Old 03-17-2005, 12:00 AM
Noah's Avatar
Noah Noah is offline
Noah has one HoF thread
The thin shiny rod is inserted down into the strut housing. Dave, are you doing your struts soon? I did my Bilsteins over the summer -- lemme know if you want a hand.
Old 03-17-2005, 07:41 AM
Since I know neither of you have a garage, you can use mine if you need it. I'd be glad to help out and get my learn on.
Can someone tell me what "re-valving" is for Bilsteins? I have seen it mentioned, but nothing says what that means...
Old 03-17-2005, 07:57 AM
If you go to the Bilstein tech site and others they explain it a lot better. But Non technical explanation, Bilsteins and some others can be dismantled and rebuilt using different size internal orifices and disks (valves). These control the flow of oil inside the shock and therefore the piston(s) movement. “Gas” shocks use a pressurized gas (hydrogen?) to limit oil frothing as the piston moves up and down, remote reservoirs provide more oil volume to help cooling. Way simplified, maybe Matt can chime in?
Steve you need to think about changing your subscript after last weekend Something like engine in – car on track
Old 03-17-2005, 10:32 AM
Noah's Avatar
Hey Dave, maybe we could go to Steve's -- I'll do an oil change, you do your struts, and we'll help Steve with whatever his car needs. (Thanks for the offer, Steve!)
Old 03-17-2005, 10:48 AM
Do you have that much time?
Old 03-17-2005, 10:59 AM
Old 03-17-2005, 11:14 AM
Ok thanks guys. I don't have this job coming up just yet, just trying to learn some things.
I don't really *need* a suspension re-do (I'm very happy with how mine is working and I don't want to change anything about it) but I do need some more brakes. If the cooling systems which I'm working on don't help, I'm gonna have to do something about my brakes but I still have the 3" caliper spacings, hence the Bilstein questions. It's a PITA and a pain on my wallet too but I'm not sure that can be helped.
Someone had fully adjustable Leda suspension installed and it was cheaper per corner than sourcing a Bilstein strut+insert. The Leda's already had the 3.5" ears which caught my interest.
I do appreciate, however, the lower unsprung weight of an upside down shock which is why I wanted to make sure that was the case with Bilsteins.
When I do source all that stuff, I will appreciate the help then.
thanks.
944 Front Frame Rails Wanted APKhaos Porsche & BMW Parts For Sale/Wanted 3 05-23-2005 02:20 PM
How to remove front spoiler? Rick Lee Porsche Technical Discussions 7 05-19-2005 01:50 PM
front axle refurb: wheel seals? }{arlequin Porsche Technical Discussions 9 04-06-2005 11:32 AM
SC Suspension Rebuild Parenn911 Porsche Technical Discussions 13 02-21-2005 04:25 PM
