What exactly went wrong here? - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Track Talk » What exactly went wrong here?
Old 01-03-2005, 04:31 PM
Default What exactly went wrong here?
I found this video on Pelican... The guy flips his Subaru at Lime Rock Park. Can one of you with some track experience view this and tell me what he did wrong?
http://www.buoy.com/~lally/car/lrprollover.mpg
The best I can tell is that he entered the turn earlier than the 911.
Old 01-03-2005, 04:33 PM
racer's Avatar
racer racer is offline
racer
I know the owner of the 911... does that help?
- 1970 914-6
- 2000 Boxster
- 1987 944
- 1987 924S
- 1978 911 Euro SC
- 1976 914 2.0
- 1970 914 1.7 / 2056cc
Old 01-03-2005, 04:36 PM
Jim Richards
I thought he was early and had too much steering input. Maybe going a bit too fast to be that early and turning that sharply, as well. Just guessing though.
Old 01-03-2005, 04:43 PM
racer's Avatar
racer
While I can't see what the drivers feet were doing. (Trailbraking, gas, both? neither?) He did enter a bit early for most cars. Curiously the rear steps out fairly early, combined that with the front tires getting an increase in grip as you climb the hill, the rear further "lightened" up and around she came... So I would summarize as Too Fast and Too Early.
I've had the incredible luck to spin on that hill and not contact anything.. Just a nice 360, put it in first and motor away. Clearly others aren't so lucky
- 1970 914-6
- 2000 Boxster
- 1987 944
- 1987 924S
- 1978 911 Euro SC
- 1976 914 2.0
Old 01-03-2005, 06:17 PM
Eli's Avatar
Eli Eli is offline
Eli
ouch....
'78 ROW SC
Duo
GONE, BUT NOT FORGOTTEN
<65 356><66 912><84 944><87 944><88 924S><87 911><90 911><91 911><99 996>
Old 01-03-2005, 06:40 PM
Quite sad, but kinda cool to watch... And the commentary is hard to beat!
Old 01-03-2005, 07:03 PM
OldTee's Avatar
OldTee OldTee is offline
OldTee has one HoF thread
Who was driving the slow Porsche we see in front?
OldTee
Sold 79 911SC
1991 Corvette
Capital One is the pits!
Old 01-03-2005, 07:49 PM
Don Wohlfarth Don Wohlfarth is offline
Don Wohlfarth
Notice how the driver is early/very early on every turn prior to the mishap. The driver was more interested in trying to set up the car in front for a pass instead of driving the line. Very early turn in, maybe 6 or 8 feet inside of the car in front. I think entry speed was OK as he wasn't rapidly gaining thru the turn on the car in front. Looks like driver was in decent shape as he tried to counter steer as soon as the car began to rotate and the tires started screaming. Can't hear the exhaust so it's hard to say but driver may have lifted as he started to countersteer.
Old 01-03-2005, 07:53 PM
There's early ... then there is EARLY . Scooby driver went way early. [edit -no cone - just red mark on armco] Don't think he would have been OK even if he stopped dialing it in and counter steered earlier and got on the gas. He would have run out of track eventually. This is a good illustration of what happens when you don't stay left (for an upcoming R) all the way to the turn-in point. I call it "creeping" b/c the driver creeps away from the edge towards the corner b/c they are anticipating getting to it and don't realize they have changed the entire nature of the corner by going early. The results also not so subtly "creep" up on you.
The uphill at LRP is an illogically early apex corner b/c as you go through it and get the compression of the hill (and it is a lot) you get more grip points to spend in the front, then you simply turn the wheel. While completing this though ... the rest of the track closes from the left in the form of an armco and you have NO run-off room to the outside of the corner. Many a 944 has had ball-joint failure on this up-hill, I've seen it a couple of times. The suspension gets a lot of load going up the hill.
If you go in sideways and get the compression while also dropping the left rear wheel off the track in the dirt .. you get a scooby rollover. It looked (sounded) like he scrubbed a little speed but not enough. Depending on how you are going ... coming onto the back "no-name" straight is a high 2nd or 3rd gear event to 4th and maybe low 5th in a 911. I usually hit max revs in 4th by the time you get to the uphill. Bang a gear to 3rd , trail-brake a little and then ON THE GAS through the compression and up the hill. The instructor mentions that the student is in 4th along no-name straight.
It would have been interesting to see what would have happened at the top of the uphill b/c if the car it not STRAIGHT you are going for a ride. most cars will get wheelspin as they cross over the hill and the car HAS to come down going straight when you re-load the suspension. (or at least the wheel better be straight (pointed to where the car is going).
I have some in-car video somewhere with wheelspin I'll have dig up for your amusement.
Old 01-03-2005, 09:19 PM
Jim Richards
Yes Jase, video PLEASE!
This may be over the deep end in the wrong direction thomschoon Miscellaneous Discussions 3 05-02-2005 11:32 PM
PPI in the DC/MD area? 911Rules Porsche Technical Discussions 52 03-04-2005 01:22 PM
Where did I go wrong? Vicegrip Miscellaneous Discussions 9 02-14-2005 12:23 PM
Correct me if I'm wrong...(PCA Picnic) VaSteve Fun Runs and Upcoming Events in our area. 10 06-29-2004 04:19 PM
