Traga Harness Bar 'Hoop' Question.... - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Traga Harness Bar 'Hoop' Question....
Old 12-28-2004, 05:48 PM
Charlie Stylianos's Avatar
Default Traga Harness Bar 'Hoop' Question....
I'm getting a Targa harness bar made with harness guide hoops. I was asked what spacing I wanted for the hoops. Does anyone have any suggestions, measurements, etc. for proper hoop placement? Is there a generic measurement that will work well or is this 'seat specific'?
TIA
Kyriakos E. Stylianos
Baglama inspired
Old 12-28-2004, 05:55 PM
APKhaos's Avatar
APKhaos APKhaos is offline
APKhaos
Charlie,
The harness hoop spacing usually comes in two forms:
- stock seats, where the harnesses run around the back of the seat
or
- race seats, where the harnesses run through cutouts in the seat back.
That should be all you need to specify.
Tony K
PCA Potomac, Rennlist Member
89 944 Turbo
85 Carrera - Sold
TrackVision
944Cup
Old 12-28-2004, 06:18 PM
ok...
Going to be running stock seats for the time being, then possibly switch to race seats at a later time. Is there a happy medium between the spacing?
Maybe I should have been more specific. Thom (on the Pelican Parts board) is fabbing one up for me, so I think he wants to know exact mesaurements. Was hoping someone with a Targa (with a harness bar/harnesses) could give me some decent measurements (from pillar to first hoop, first hoop to 2nd hoop).
Thanks again.
Baglama inspired
Old 12-29-2004, 06:55 AM
We use the Brey Kraus harness bar w/an older style roll bar. Spacing has seen ideal with the stock seats, the DADs, and my Kirky racing seat. If you can wait I’ll measure it tomorrow and repost or you can e-mail Kraus for the dimensions. Since mine is for a coupe I’ll measure from the center line to eliminate the width differences between coups & Targas.
Old 12-29-2004, 11:25 AM
William Miller's Avatar
William Miller
While your measuring, how high is the bar? Off the floor or some other point?
Thanks!
Thanks! WCM (Bill)
'81 911 SC Red Targa 3.6
'08 335i Blue Sedan
'05 Chevy Tahoe green
'98 Jeep Cherokee XJ "Blue"
'01 Toyota 4 Runner "Pearl"
Darnestown, Maryland
Old 12-29-2004, 11:49 AM
David, that would be great. No rush on the measurements.
Baglama inspired
Old 12-29-2004, 11:53 AM
These bars typically mount using the stock upper shoulder harness bolt on either side. So height would be at the horizontal between those two points.
Old 12-29-2004, 12:16 PM
flatsixcrazy's Avatar
flatsixcrazy flatsixcrazy is offline
flatsixcrazy has one HoF thread
Hi charlie,
I have a BK bar in my garage that came out of my 78SC. If you need to see how it would fit into your targa, you are welcome to pick it up and installed it into your ride and take measurements. Or you can test different loop positions on the bar to your seats. Andy
Andy
11 Cayenne S White/Tan SUV
91 964 C2 Black/Black Cabriolet
72 911T Black/Black Coupe
73 911E Bahia Red/Black
66 911 POS Tribute (Yes, but its MY ugly)
Old 12-29-2004, 03:14 PM
William Miller
David, I'm not sure my cab has the same height sholder belt attachment.
I was hoping to use the mount points for the porsche factory roll bar. I'm now thinking that it won't work because it's a few inches lower. Possibly below sholder height. I'm planning to keep the stock seats for now but alos planning for the future. I do need to buy/build a roll bar. So I'm looking to determine the height for a horizontal bar that will also be used to attach a harness.
Thanks!
Thanks! WCM (Bill)
'08 335i Blue Sedan
Old 12-30-2004, 08:06 PM
Using a harness bar in a coup is a poor idea, in a cab, well just say not good
There are some on this site that have installed bars in cabs to good effect. Adding harness guides to the horizontal brace of a roll bar would use the same center line measurements.
Newbie Question Regarding Bleeding Brakes TD in DC Porsche Technical Discussions 21 05-26-2005 07:54 AM
Mid-Ohio Shift Point Question TD in DC Track Talk 15 04-26-2005 10:47 AM
harness shoulder straps? Mackpipes Track Talk 13 08-12-2004 04:28 PM
Potomac Question HPDC Question Doug E Track Talk 43 09-30-2003 07:36 PM
