I was wondering if anybody had any advice for a buying a pressure washer, I never had one and was wondering what I should look for as you can always use another power tool.
Thanks Thom
'81 SC Euro, garage queen '02 Boxster $, stuck in depreciation cycle '82 Crossle 50F Formula Ford '96 Argo Formula Asia (similar to F3 but with DOHC 2 liter) |
Rent one
I have a nice Honda powered Karcher (sp?) and it works great. Thing is, I only use it once or twice a year.
The Honda one are nice. I would also add:
Be careful with the nozzle, don't use the stream on any painted surfaces. Don't keep it in a freezing cold shed or garage; if you do, run biodegradable antifreeze through it.
Drew Sierra- 91 Zermat Silver 964 Turbo |
Honda is good. I had a Craftsman that worked for a while then cracked a screw on the pump housing. New pump=new machine. The cost of the new pump was about 15 less than a whole new pressure washer.
I was told by the mechanic that they are only designed to run for 5 hours. That's BS but be careful of harry homeowner crap because it is cheap, it won't last long, it will break and you will have to throw it out. Don't let lowest price be the winner.
Hunt 611racing.com OG Racing Team Vimeo https://www.youtube.com/user/Streak986 1999 SPB #611 2004 Wrangler “That’s how people like you work. Your ego is so out of whack that it will do what ever it can to protect itself. And people with a messed up ego can do these mental gymnastics to convince themselves they’re awesome when really they are just douche bags” - Kyle, South Park "If you need to focus maybe you should buy the book and take it home" - MLIN |
I bought a Karcher w/ a 6.5 Honda at Costco last year and it has been great. Would buy it again.....
keithmckenney 99 996 tip (staying put) 90 964 targa (gone) 88 951 gone 88 911 (gone but not forgotten) 69 912 (our first but it rusted away) 94 2JZGTE 76 FJ40 14 R1200GSw |
Chris has the right idea about renting, but…
If you’ve never had one I’d buy a small 1700-2200 lb electric one to see if I really wanted the hassle. The whole thing is a bust unless you have a good place to store it. Hoses are stiff and difficult to keep neat; nozzles are long and just add to the clutter. Higher presure units multiply this. Add a gas engine to maintain; cause as stated most don’t’ get used much and gas does go bad and even small engines need oil changes and the whole thing will just become something else that needs to be shifted from one spot to another
Bad experience with the Karcher from Costco. Soon after purchase it wouldn't hold steady pressure. Called customer service and they said I needed a "upgrade Kit". They knew the original pump was garbage and now were go to stick me for another 80 bucks:XX . On the positive side, makes quick work of cleaning just about everything.
John Hallen 69 911T Targa 01 Harley FXST 01 E46 325CI 05 Kubota BX2230 |
I went with electric due to size and ease of convenience. Nothing less than 1500 lbs though. The small ones just aren't strong enough.
2002 C2 Cab 1982 911 SC Targa 1978 911 SC Targa 1976 911 S Targa Formerly: 1964 scca C coupe 1965 C coupe 1968 912 Targa 1970 914/4 1985.5 944 (glutton for punishment) Now a Potomac Member (sorry guys) Also: Bugeyes, Vanagons, Fiat Spyder, Ducati 916, BMW R65RT, '78 xs11, cB750k0, ct90k0, ca110 ..... Nature knows no indecencies; man invents them. Mark Twain ...then there was this mind reader who moved to Washington DC and couldn't find work. |
+1 on the renting part. Unless you have a lot of storage space and keep it mildly heated in the winter.
I got a free wimpy electric one, really for very light and small jobs. Had points on a corp credit card that I needed to use up when I was changing jobs once. If buying one, get the most powerful one you can afford. They big ones that I rent really make quick work of just about anything you throw at them and the little ones take all friggin day to do a remedial job. Think Tool Time..... more power..ugh.
-Paul |
