Please pardon my ignorance, but is there a 'tried and true' method for changing the oil in my 911SC so I don't overill/starve my 3.0? I've been told that the true level of the oil is determined on the dip stick and to not rely on my gauge.. Also what brand is best? It currently has Castrol 20-50...should I change or continue to use it? I'm a novice Porsche owner, but been a big fan of these cars for many years. Can anyone help me or direct me to where I can get this info?
Thanks!
Charlie 78 911SC Let's Tee It UP! |
*When I say I dumped it, I'm not kidding. The tank holds a lot of hot oil and it comes out REALLY REALLY fast. If you have one of those pans from Auto Zone with the tiny hole, cut it open now and save yourself the trouble of cleaning off the driveway or garage. For more funny stories, do a search on Pelican, lots of good stuff. Lastly, welcome to the board. Where are you located? Hope you can make it out to an event or an engine drop. Who knows, it could be yours.
VaSteve,
Thanks for the info! I would have surely dumped hot oil all over my garage as I do have a donut hole oil pan! What do you mean by "crush washers"? How many will I need?
Thank you! I live in Manassas Park and would like to come out for a fun run and/or engine drop!
This is what you need for an oil change, I recommend using a Mahle oil filter:
![]() Crush Rings: ![]() One of the crush rings is for the drain plug on the sump plate: ![]() and the other crush ring is for the drain plug on the oil tank: ![]() You need to drain the oil from both places when changing the oil. If the drain plugs are on too tight, you may have to tap the wrench with a small hammer to break them loose. I highly recommend buying the Bentley manual for the SC's and/or 101 Projects for Your 911, both are good resources. |
This is excellent! Thank you! I ordered those two books from Pelican Parts...
I appreciate your help!
Pari, please tell me you just took those photos....Why Oh, why would you have that on your computer.
Okay, I'll bite..."BFE"?
http://www.acronymfinder.com/af-quer...exact&p=ol :P
| What are the going rates for an oil/filter change? | Noah | Porsche Technical Discussions | 43 | 03-18-2005 03:02 PM |
| Change of Plans - Home PPI | frogers911 | Porsche Technical Discussions | 23 | 01-10-2005 01:33 PM |
| 996 Oil Change | ecohen | Porsche Technical Discussions | 7 | 12-27-2004 10:03 PM |
| First spark plug change this evening, do I have it right? | 4to8m8 | Porsche Technical Discussions | 7 | 12-17-2004 08:17 PM |
| WHEEL CHANGE | cmbenz | Miscellaneous Discussions | 13 | 06-09-2004 05:08 PM |
