Upgrade / Some other stuff - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Problems, Support & BBS Questions » Upgrade / Some other stuff
Problems, Support & BBS Questions Please post board related problems in this section for resolution. We know there are some furballs out there so let hear about them.
Old 11-15-2006, 12:20 PM
admin admin is offline
admin has disabled reputation
Default Upgrade / Some other stuff
You have been upgraded to Vbulletin 3.5.6 for the time being until the MySQL upgrade is complete at which point the board will be moved to vbulletin 3.6.3 or higher if available.
BE Aware:
You are running in a different directory so some of the images / smiles / avatar stuff is broken until the final upgrade is complete. This is not a permanent situation.
I.E. 7.0 doesn't work well with the installed version of vbulletin 3.5.6 but should work correctly with 3.6.3
I am considering moving the gallery again back to the menalto gallery from the vbadvanced version because the vbadvanced one in my opinion stinks. This is contingient on embedding options and full support (i.e. image choosing inline with posting). This works on my blog so should be a viable option here.
Sorry for the outage, the board was severely... severely out of date and becoming a potential hacker threat.
No I don't regularly monitor this forum other than from an adminstrative stand point.
If you have additional questions I will be monitoring this thread for the time being.
Old 11-15-2006, 12:38 PM
Re-opened.
Old 11-16-2006, 10:34 AM
Default Upgrade Done
At this point the major portion of the upgrade is done.
The board is now at the most recent version of vbulletin.
I won't offer a lot of detail, but there was a major under the hood overhaul as well.
Please post issue you encounter here with the exception of the avatars. I am aware that they are not working correctly.
FYI in the future if you get a database error please be patient. Every time you hit it afterward you are generating email to me. I got over 100 in a very short span before I had to hide the directory. This is very annoying because it causes my phone to go nutso.
thanks,
Old 11-16-2006, 10:49 AM
wludavid's Avatar
wludavid wludavid is offline
Prodigal Pariah
wludavid
Can we turn the 'quick reply' back on by default? As it stands now I have to click on 'Post Reply' and then go to another screen to post something.
Old 11-16-2006, 10:55 AM
Sure this must be a feature inside the Admin Control Panel. This is probably something better to defer to JazzBass as he is the real admin.
V/R,
Geoffrey
Mackliet's Avatar
Mackliet Mackliet is offline
Mackliet
Not sure if this is a database error or not, but when I click on Forums, I get this error:
HTTP 404 - File not found
It is trying to go to this URL:
http://www.dorkiphus.com/porsche/htt....com/index.php?
Bruce Mackliet
Vienna VA
86 944T
Gone
92 Carrera Cup USA
87 944T
95 Cab
Old 11-16-2006, 11:00 AM
Default Bad Link
Thanks,
I haven't rebuilt the CMPS portion of the site at this point. Should be done today as well...
Site may seem slow. The search and thumbnails are being rebuilt.
-Geoffrey
