Dr K's Project Car - Page 81 - Dorkiphus.net
Old 09-22-2010, 10:50 PM
Got the GHL exhaust system off tonight (MUCH easier than I expected - the header/heat exchangers came right off even though I could barely reach some of the nuts with a wrench -- 1/32 of a turn (which took a bit of force) and the nuts screwed the rest of the way off by hand. NOTE: Matt suggested NOT to use the locknuts that I had bought when we put these on. I did lose 2 nuts at VIR, and after that kept checking to make sure they were tight (none ever loosened up again). I'm strongly considering using copper nuts (unless I hear otherwise) on the headers when I put them on. I would have done that tonight but the outflow flanges are a little rough, and I'd like to put them on a belt sander before I put them on the car.
If the local shop has time next week, I'll have an H-pipe setup fabricated for the Flowmasters. If not, I'll put on the megaphones (what? I can't hear you...).
One question: if I have the Flowmasters done, I'll have an O2 bung welded on the outflow pipe from the driver's side exhaust (on the next pipe, not on the headers). But if run the megaphones, there's no place to put the O2 sensor. I'd be interested in people's comments about running without the O2 sensor for a race. I've heard Matt and Jazz's comments already (exactly opposite). Also, is the O2 sensor bung standard across the industry? I ordered a "weld-on" one from Amazon.com (will be here on Friday).
Old 09-22-2010, 11:54 PM
I know you will disagree but all bungs are the same.
Weld in place then drill the hole in the middle.
Old 09-23-2010, 07:52 AM
ROTFL! Id reverse the latter directions though, else you might not be able to screw the sensor all the way in.
1984 930 - 3.6L
Old 09-23-2010, 11:25 AM
markwemple's Avatar
markwemple
I am the great cornholio........
2002 C2 Cab
1982 911 SC Targa
1978 911 SC Targa
1976 911 S Targa
Formerly:
1964 scca C coupe
1965 C coupe
1968 912 Targa
1970 914/4
1985.5 944
(glutton for punishment)
Old 09-23-2010, 01:02 PM
realroadrage's Avatar
Trust.....but verify
realroadrage
If this car is basically done, shouldn't we close this thread? Otherwise, we'll be reading about every frickin' miniscule thing that Dr. K does with this car.
Everything has changed
Old 09-23-2010, 01:14 PM
Cliff Claven Cliff Claven is offline
Cliff Claven
as in:
well it turns out my gas tank has run dry and i need to refill. does anyone have any gas i can borrow?
Old 09-23-2010, 01:47 PM
He wanted to close it but couldn't get the modz to do it never PMed I suspect
I gotz all the gas you need cliffy but I expect it back by the weekend
Old 09-23-2010, 02:17 PM
Cliff Claven
i have three gallons of vintage gas from 1983. this is the good stuff, the way they used to make it back in the good ol'days. it is still in the tanks on the two motorcycles in my basement, neither of which has been run for 25 years. just come by and siphon it out.
Old 09-23-2010, 02:22 PM
Fritz's Avatar
Fritz Fritz is offline
Addict
Fritz has one HoF thread
I'll take it! I'll even help you get rid of those useless motorcycles taking up space.
Old 09-23-2010, 02:55 PM
markwemple's Avatar
markwemple
I'll take 2nd place. I'll find a home for the gas and ride the poor things. (after Kurt helps me get 'em runnin')
2002 C2 Cab
1982 911 SC Targa
1978 911 SC Targa
1976 911 S Targa
Formerly:
1964 scca C coupe
1965 C coupe
1968 912 Targa
1970 914/4
1985.5 944
