So it runs but... - Page 2 - Dorkiphus.net
Old 03-31-2021, 11:20 AM
What "extra connectors do you have? You might have the harness routed wrong or something if no appropriate wires reach. A way to see if you found the right wires is to ground them with the key on. The gauge will go from hot to cold or light on/ off. (Check for 12 V before grounding some random wire)
Oil pressure light and stock pressure gauge are G/w and G/r or vice versa IIRC. Temp should be nearby in the harness.
Old 03-31-2021, 08:20 PM
Tito
86911TLCAB
On the SC they both run through the 14 pin connector. I think it’s the same for 3.2. So should come from left side of engine.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
Old 04-02-2021, 04:19 PM
pookie's Avatar
pookie pookie is offline
pookie
I got it! Thanks Tito for the calls. The wire was pinched between the rubber seal that goes between the engine and body.
1976 911S Targa 3.2 swap
Old 04-03-2021, 09:49 PM
Old 04-04-2021, 08:10 AM
Congratulations
Lucky owner of a couple 911s
1965 Honda Sport 50
