...unless the neighbor saw it unloaded from a flatbed in front of Otto's house
#12
Um, good point........
Ken 2023 Audi Q7 Daily Driver Considering next Porsche 1990 964, Red, Number 692 (Misty) sold 2010 Trailex (Dusty) sold 2003 996, (Speedy) Grey sold Life is short; just drive....... (boat, bike, etc.) |
#13
Otto, let me know how much they charge you for a "clutch adjustment" on a Boxster. May be my next business venture now that Barnum & Bailey is shutting down.
#14
I highly recommend you don't fix the IMS bearing. It's likely better than the one they'll put in. It's a 2006 so it should have the updated one anyway.
Yes, experience...
Dave 2006 Cayman S, #25 2014 Cayenne Platinum Diesel 2012 VW GTI |
#15
Also, M97 requires you open the case to replace the IMS bearing so not an out-patient process.
Good way to find out if your shop knows Porsche. "If I drop my 2006 9X7 off for the afternoon how much will you charge me for a clutch adjustment and an IMS change?"
#16
well
the engine seems to run fine no noise change that i have detected so far on start, and fast idle, there was a markedly different vibration i let it run a bit to warm up the vibration seemed to be less when i revved it up a bit i only tried 1st, then reverse, then 2nd - no joy - then i shut it off
#17
Otto, try this quick rule-out. Make sure the A/C is off and try again with the start up routine. Probably not it but worth eliminating the A/C pump drag.
NM, I forgot it was a transmission issue since you can't get it in gear... 1. Check the brake fluid reservoir level. Is it where you last saw it? The clutch is hydraulic, hence my adjustment comment. Is there a puddle under the car you didn't put there? 2. Does the shifter move freely? Is it easier or harder to shift than normal. There are cables going to the transmission that are known the pop-off at the transmission end. Maybe it was stuck in an awkward spot. Can you hear the 'cachunk' of the transmission going into gear when you shift into each position?
Martin 2011 Cayman S (Gone) - Hardtop Blechster 2006 Cayman S (DD) 2016 Mazda CX-5 (Her DD) 2002 Boxster S (Gone) - Ragtop Blechster - Pura Patina! Dorkiphus: I buy it for the articles Last edited by N0tt0N; 05-02-2017 at 08:17 AM. |
#18
If it will not go into gear one of the shift cables may have broken. A common problem on Boxsters and Caymans. If that's the case replace them with Numeric cables.
Mike 14 981 Cayman S Wall of Dearly Departed Loved Ones 07 987 Cayman S 03 996 86 944 74 914 78 924 Bro Code Rule 43: When a Bro learns another Bro has been in a traffic accident, they must first ask what condition the car is in. |
#19
So, if Otto needed a new IMS, it can still be done on his car without splitting the case. However, as mentioned above, I wouldn't go for a new IMS bearing unless you are starting to see warning signs (noise, metal in the oil filter, bad cam deviation numbers, etc.).
#20
man, all kinds of good stuff - thanks for the pointers
so, the durametric can show cam deviation which is an indicator of an ims failure near? i will check several of these other things as well tonight
| Thread Tools | |
| Display Modes | |
