Wet spark plugs - Dorkiphus.net
Old 01-16-2024, 10:05 AM
Tim P Tim P is offline
Tim P
Default Wet spark plugs
Good Morning,
Hoping I can get a little help here. I was changing the plugs and coils on my 04 Boxster yesterday and noticed 5 of the 6 plugs were damp. The 3 on the right were wetter then the left. I remembered reading in the past that there were O-rings on the tube that can cause this problem. When I started to reasearch tube and o-ring replacement I could not find info on the 04 2.7. Looks like the tubes were only available for 97 - 02 engines. I did see that one o-ring was available for 97 - 05 engines. Does the 04 2.7 have a removable tube? Is it reusable? What o-rings should I order if they are replaceable? If not removable what is the fix? I did not have this problem in the past times I changed the plugs/coils.
Thanks.
Tim
04 Boxster
88 944S
87 944 Turbo
