Backside Valve Adjustment - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Backside Valve Adjustment
Old 11-19-2014, 08:24 AM
BMAN's Avatar
BMAN BMAN is offline
Cushion Convector
BMAN
Default Backside Valve Adjustment
Anyone use the backside go/no go method? Downside?
Ordered a set of feelers and just want to make sure I can get them under the rockers. NooB at this and don't know what room is available to slide the feeler in until I get the covers off. Is there a particular length or style of gauge required?
Here's a pic. How did that gauge get in there?
_______
Brian
'71 T
'72 E
'80 Weissach SC
'94 C2
'05 996 GT3 CUP
'11 GTS/C4S Donuts
'15 Boxster S #Blubyu
Old 11-19-2014, 09:08 AM
Tito
86911TLCAB
I have used it and been successful. Had a recent experience where it wasn't as successful, but it wasn't because the method is flawed (I rushed it). I would do them first the normal way and then use the backside as a test.
The feeler gauge slides up from the bottom (or down from the top)...once you get it all apart you will see how it works...
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
Old 11-19-2014, 09:35 AM
^^^ Agree. I used the backside as confirmation after sliding the feeler in the normal way. I can bring over my Haynes and Bentley manuals. Between them, they explain things nicely with good photos. IIRC, I was most worried about being certain I was at TDC on each cylinder.
Old 11-19-2014, 11:27 AM
Richard Curtis's Avatar
Richard Curtis Richard Curtis is offline
Richard Curtis
You'll need the long, flexible feeler gauges, I believe.
Richard Curtis
Fairfax Station, Va. '93 911 C2
Old 11-19-2014, 11:59 AM
ducatithunder's Avatar
ducatithunder
Anyone used that new tool on pelican. Its a version of a micrometer that sets lash by counting the adjuster screw turns. Its said to be spot on and really easy to set the lash.
http://forums.pelicanparts.com/911-e...ment-tool.html
Current
07 Mini Copper S
99 Dodge Viper ACR
65 Shelby 427 SC
07 Ducati 1098
17 Alfa Giulia Quadrifoglio
Projects
86 "Backdate" 911 2.8 RSR
73 911 T Targa (Sold)
Old 11-19-2014, 12:06 PM
Tito
86911TLCAB
My problem when doing the valves is being able to prevent the valve from turning while I tighten the 13mm nut. I forever end up tightening the valve and getting it out of adjustment. need to find a good tool to prevent that from happening or start to work on my hand strength.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 11-19-2014, 12:42 PM
See this thread for help: http://dorkiphus.net/porsche/showthr...=15344&page=87
Old 11-19-2014, 12:59 PM
Tito
86911TLCAB
thanks
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 11-19-2014, 01:28 PM
I use one of these:
Old 11-19-2014, 01:56 PM
BMAN's Avatar
Cushion Convector
BMAN
Thanks for the replies!
I will likely double check everything via the front and backside.
Does it move even when your using a screw driver on the valve? If so, I can understand how Jazz's screwdriver can help hold it in place. Gotta buy another tool!
Saw this tool on Pelican too and SSI had one.
http://stomskiracing.com/products.php?id=67
_______
Brian
'71 T
'72 E
'80 Weissach SC
'94 C2
'05 996 GT3 CUP
'11 GTS/C4S Donuts
