944 Suspension Refresh - Page 4 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » 944 Suspension Refresh
Old 08-14-2012, 01:59 PM
ruffyz ruffyz is offline
ruffyz
Originally Posted by ausgeflippt951 View Post
What's your timeline looking like on this? Did you see my response to your PM -- the car will be on jackstands for the next few weeks but after that will be good to go...
Also, did you mean "redoing the t-bars"? Not sure where the TT came into the conversation.
I'm in no hurry really. Yeah, torsion bar is what I meant. The TT is a whole different ballgame of annoying.
Old 08-14-2012, 02:21 PM
To those that remove the t-bars, does anyone make a 935 style spring plate replacement for 944s? (a fixed plate + rod end for toe?) Would be simpler to install & adj than the elephant polybronze.
1984 930 - 3.6L
Old 08-14-2012, 02:24 PM
APKhaos's Avatar
APKhaos APKhaos is offline
APKhaos
Never seen one. Most go with the stock trailing arms, which are pretty much bombproof, and coil over setup.
Tony K
PCA Potomac, Rennlist Member
89 944 Turbo
85 Carrera - Sold
TrackVision
944Cup
Old 08-14-2012, 02:28 PM
RedOctober's Avatar
RedOctober RedOctober is offline
RedOctober
Originally Posted by ruffyz View Post
Anyone want to give me a ride-along in their '44, so I can get a feel for different spring rates?
I am not exactly close to you, but I would be happy to give you a ride in my '86 with 425# springs in the front, and 30mm T-bars. Sways are not stock, but are not the biggest either (can't remember the sizes now).
If I can change the T-bars, ANYONE can (although I did have some help from good samaritans on this board).
_______________________________________________
Tim M
'00 C5 Corvette FRC track car
'86 944 N/A (aka Doublemint) - Past
'20 Ford Expedition Max
Old 08-14-2012, 02:37 PM
I SOLD that car so I wouldn't have to do this job, and still got the opportunity to participate.
Old 08-14-2012, 02:42 PM
hobiecat's Avatar
hobiecat hobiecat is offline
hobiecat
If you don't mind me asking: do you suffer from understeer? IME, 30mm T-bars lend themselves a bit better to 350# springs. Then again, what sway bars do you have? I'd be hesitant to go with 400# springs + 30mm T-bars in an N/A since you don't really have many ways of inducing oversteer at that point!
Then again, it also depends on your driving style + other mods. My setup (350# + 30mm) is with a stock interior/panels/wt distribution, so YMMV.
I wanted neutral and that's exactly what I have. (Sliding around corners is for 911's....and I guess 944 Turbos?).
I have enough problems to overcome driving a lower horsepower car.....so the way I see it, sliding simply means
I'm losing momentum. Losing momentum = bad.
The car is very neutral and sticks. I am always pleasantly surprised when I push it beyond the point where I think it
should get loose. So - it's still got more and I still have more to learn from it. When I get past that point, I'll be looking for an upgrade.
I also did the full Elephant Racing upgrades - my control arm bushings were replaced with sealed bearings, and I
went polybronze on the spring plates.
Do I think it's the absolute best setup for me? Yep. For someone else? Maybe not. All I know is I like it the way it is.
Jim B.
Maryland
1987 944S - Black #303 - Zeus Suit Racing
2007 Boxster S - Carrara White - Daily Driver
"Life is too short to have a boring car"
Old 08-14-2012, 03:05 PM
Good. Learn with the car you have until you can't learn anymore. Then take it to someone and have them look it over and tweak it.
I can get some nice neutral sliding with my car, it's fun!
Old 08-14-2012, 03:15 PM
ausgeflippt951's Avatar
Shock Whisperer
I'd be curious to see what that would look like; I'm not familiar with 935 rear susp. Sounds intriguing, but then again these are 944's here so the idea of upgrading to a 935-based anything is not typically a sentence one hears very often. Other than the K27/6 or K27/8 (which I'm not sure the 935 even had).
Cool -- very good to know. I've been very pleased with the neutrality of my car as well which made me scratch my head. Then again, a well-handling car is due to a host of factors, not just one; e.g., perhaps you're running different-sized tires than I (I'm 225/245R16).
Controlled four-wheel drifts through T10 @ SP? I just got to experience some of that action this weekend. It's like an adrenaline shot straight to the heart.
Collin M.
I wear a cowboy hat.
'06 M3: hers.
Old 08-14-2012, 03:24 PM
hobiecat's Avatar
hobiecat
Yep....I run 15x7's all the way around. 235/50R15's.
Jim B.
Maryland
Potomac-Greg's Avatar
Potomac-Greg
What didn't you like about #1? Interesting to hear. I personally don't have much experience with #1; my current car is #2 and I love it.
The #1 option (keeping torsion bars and adding coilovers) limits your ability to lower the car unless you want to re-index the torsion bars -- and if I was doing that, I'd just get stiffer torsion bars. Also, if you use both spring methods, then you need to buy a set of zero-rate helper springs for the coilovers because there will be situations where the coilover extends itself beyond the coil spring length (e.g. entering a steep driveway at an angle), and the coil spring might get hung up on the coilover when it comes back down.
Lastly, option #1 was a compromise based on my lack of mechanical courage. It took several more months before I built up the courage to take out the spring plates. As confirmed this past weekend, the car still hauls ass under new ownership!
Greg
Rockville MD
