944 Turbo Clutch Replacement Cost - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » 944 Turbo Clutch Replacement Cost
Old 11-13-2011, 09:03 AM
Potomac-Greg's Avatar
Potomac-Greg
There's also a guy in Indian Head MD who does all sorts of work on the cheap. He does a lot of work for 944 cup racers. No cappucchino and biscotti in the waiting room, but I hear he's cheap. You may be able to find his name on 44cup.com. Tony P may know.
Greg
Rockville MD
Old 11-13-2011, 10:31 AM
TurboPooch's Avatar
Now known as Robbie's dad
TurboPooch
+2 on Sloan at SSI. He knows these cars inside and out and will do it right..the first time.
The shop manual specifies arond 22 hours labor IIRC. If this is the original clutch you can bet it will be every bit of it. I've done this job before and because all of the exhaust and drive train need to be removed/dropped it is time consuming especially when it comes to bolts that have not been removed and have rusted for the last 20 years. There are some tricks to doing this job properly/efficiently that are not in any manual and only learned from experience.
89 944 Turbo Race car
98 993 C2S w/Aerokit II
70 Boss 302
86 Mustang SVO
24 F250 SD Godzilla
Old 11-13-2011, 12:29 PM
Mark in Baltimore's Avatar
Mark in Baltimore Mark in Baltimore is offline
Mark in Baltimore
PM sent.
-'96 993 - polar silver
-'03 BMW E39 M5 - LeMans Blue
-'06 Acura TL (manual gearbox winter beater) - white diamond pearl
-'17 Macan GTS - agate gray (SOLD)
Old 11-14-2011, 09:35 PM
scotty b's Avatar
scotty b scotty b is offline
scotty b
IIRC book time is somewhere near 20. 16 I believe. Real time is closer to 14 for just the clutch for someone that has done it before. Yes it is a bit more involved than an n/a as the crossover pipe for the turbo needs to be removed. With that you get into large rusty exhaust bolts that are a major PITA to remove and most of the time need to be replaced. On top of all the other " while your in there's " listed, you can count on needing the flywheel surfaced. As for the rubber hub, the turbos never had it. Porsche only used a normal spring disc in the turbo's
Old 11-15-2011, 04:22 AM
njayellis njayellis is offline
njayellis
So getting an aftermarket clutch kit like the Spec 4 w/o spring disc is ill-advised? Is a Sachs or other OEM rebuild kit the way to go, even with a chipped car and track use on the horizon?
Jay
Jay Ellis
'87 951, Lindsey Quad MAF, 3" SS Exh
Enduro/Sprint 100cc Kart
TAG 125cc Kart
'13 Durango Tow Vehicle
Old 11-15-2011, 09:23 AM
Marc A's Avatar
Marc A Marc A is offline
Marc A
Others may not agree, but I would not put a solid centered clutch on a 944. I don't know whether the Spec 4 clutch is solid centered, but assume that it is by your question. The spring centered clutch absorbs some of the shock when the power is put down to the drive shaft. This is important because it puts less "twist" on the drive shaft itself, which actually twists as well as rotates. Just my 2c.
Here's the clutch I put in before the conversion: http://www.clutchnet.com/clutches/de...s7291?sef=hcfp
Not for the street as engaging 1st and Reverse was a bit juddery but it gripped like no tomorrow.
'05 Mustang GT
'08 E350
'06 LR3
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone
The 958 Conversion
Old 11-15-2011, 09:43 PM
TurboPooch's Avatar
TurboPooch
Call Jason at Paragon and order the cup clutch kit. A little pricey but I have had one in the race car for several years with no issues.
70 Boss 302
86 Mustang SVO
24 F250 SD Godzilla
