| Tools Needed/For Loan If you need to borrow some tools, or have tools to loan, post here. |
I have ordered some new ball joints and tie rod ends to go along with the a arm bushing replacement...does anyone have the ball joint socket i may borrow sometime in the next month or so...thanks...
I do. U no you don't use it to loosen?
use an air chisel to remove. I'm going to Riley's house tomorrow if you'd like me to pick it up
Thanks. Yes Dave, i read that its only for install...
Steve, appreciate if you would get it and i will get it back as soon as possible...
Front hub socket for a 4 wheel drive fits too. $10 to $20 at your local FLAPS. Knock the ring off with a hammer and dull chisel and take it with you to the auto parts store for fit. Heat is your friend. heat the ring to gootenhot before beating on it.
sounds good...
Thanks Kurt...will pull the old lighter out when i am ready to start...
Socket left with VaSteve this evening...
It's in the car! Come on by Tito.
thanks dudes...
