I was thinking maybe air relief for oil cooler and maybe brake duct routing.
Now that you have a dedicated thread, how about a description of the build?
Well, Kurt, welcome to Hell for cutting up such a pristine tub. Your punish will be lookie no touchie for eternity.
Looks nice though . . .
Thank Me Dammit! |
I'm finding I have an admittedly perverse desire to run my hands all over that naked tub. I could even just stand there and ogle for hours.
Sick, no?
Rich F. 2017 BMW M240 xDrive Vert 2004 BMW 330Ci Coupe (DD) 1996 BMW 328i 2006 Cayenne S 1980 SC Targa (A1R KULD) Gone but not forgotten: 2010 Boxster S (sold) 2000 Boxster S (sold) 73 911T Targa (sold) 67 912 (sold) |
Kevin Oyler '88 944 Turbo S "Don't let a few facts get in the way of a good story" |
It is real cool to see how the thing was put together and it is far more obvious when all is exposed than when in paint. This stamping got spot wellded to that one then the sub assembly was spot welded to some other sub assembly then all was presented and spot welded in. That kinda stuff. Real rough welding in many places you can tell where it was done by hand or not. I think much of the spot work was by hand as it is very uneven in aplication on places.
#16
Kurt:
WYIT - think of installing SRP "R control arm pivot box upgrade kit" [#562010 - 911 arms, #562020 - 930 arms] for dialing in more R camber. Have installed on both our 3.0L and 3.4L cars. Aditionally, welded tubing [or 1" square] to brace torsion tube [behind where brackets are for trailing arm attachment] to transmission tunnel [easy access if you are removing R seats for access panel] b/c this area will crack and break away under high stress [track car, sticky tires, slicks...?]. Has become SOP at most race shops building race 911s putting out ~300hp+. Stress issues become worse with 930 arms and 14" slicks On one car we welded in a plate in the tunnel for the 1" square to attach to [rather than sheet metal] and then ran the square to the torsion tube [attaching R behind where the SRP R control arm pivot box(s) are installed]. Here is a link to the pivot box install instructions from SRP. In figure B in the instructions you can imagine the tubing we installed to the torsion tub coming in from the left and attaching to the tube. Food for thought. |
#17
Am already building my own set of R arm Boxes. SRP should have not put the instructions on the website if the expect to sell them to a cheapskate reverse engineer like me.
1. Finish up cutting and cleaning up the tub. 2. install drivers compartment cage and body stiffining extensions. (the fun part) 3. figure and set up oil system device locations such as oil tank, cooler and cooler ducting and fuel cell setup. This all plays into the front fire wall reinstall. (waiting on oil tank, have cell in hand, thanks to Mark A) 4.Front fire wall will be a lot of work to fill in all the holes but is required to remain in place by PCA CR rules. Dealer installed AC just riddled it with even more giant holes that normal. I will replace badly cut and mostly hole sections using same guage materal and follow the original lines except where the oil tank will be set. That area will protrude into the pass side foot well and be fully metal firewall boxed from the A piller root across to the tunnel. I have seeen this area modified in GT case befor so it should be legal for me too. Upper section will slope up to windsheld base and behind the cage cross bar. This will isolate the tank and fuel cell from drivers compartment and add a little geometric X bracing too. Jase do you have pix of you tubing and susp reinforcments? Allways looking for good ideas.
#18
Kurt, I'd be interested in seeing your camber boxes. I too have thought about reverse engineering them (I made my own trailing arm monoballs, and a camber box looks simple in comparison - but pictures always help.)
SMD ________ Wifes first black cock Last edited by smdubovsky; 04-19-2011 at 04:17 PM. |
#19
I'm interested in this kind of stuff too.
We will now use the power of the Continuum Transfunctioner to banish you to Hoboken, New Jersey. BMW Spec E46 #609 |
#20
In the theme of adding lightness ... one of the race shops out there has the bucks for FG and CF rockers [inner and outer]. Not exactly legal though .... |
