Front Wheel Bearing Replacement - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Front Wheel Bearing Replacement
Old 10-25-2023, 02:35 PM
cmcfaul@aol.com cmcfaul@aol.com is offline
need for speed
cmcfaul@aol.com
Default Front Wheel Bearing Replacement
Hello,
I have to replace a front wheel bearing on my 89 Carrera. In the past I have beat the old race out with a hammer and beat the new one in with heat and a bigger hammer. This time around, im am asking the collective if anyone has a press that will do the job infinitly easier.
Many Thanks,
Chris
89 Carrera
73 911 E
703-967-2990
cmcfaul@aol.com
73 911 E
89 Carrera
Old 10-25-2023, 10:33 PM
When I did this with Matt De Maria, we beat out the old race with a "cove chisel" and a hammer. Used a press to put the new one in.
Doing it myself, I use the "US General" (Harbor Freight) Bearing Race and Seal Driver Kit to place the new bearing (aluminum so I wouldn't use it with a press). You're welcome to borrow.
Old 10-26-2023, 06:36 AM
jhsmith's Avatar
jhsmith jhsmith is offline
jhsmith
For the rear bearing on a 993 I put the bearing in the freezer overnight then pressed it in with one of the screw driven bearing presses. Much easier getting the new one on than getting the old one off. Perhaps the freezing helps?
Jim
"2014 & 2017 Central PA SCCA Witch's Rallye - Best Team Costume Award"
White/Green '91 SSM Miata #01
Silver '00 Miata
Green '96 911 (993) Carrera #409
Blue '09 911 (997.2) Carrera S Cab
Black '15 Yukon XL w/ '98 Trailex (Tow Vehicle)
Burnt Orange '75 FJ40
Yellow '19 718 Boxster (wife regretfully sold it to fit the grandkids)
Black '83 911SC Targa (regrettably sold when the second car seat didn't fit and 2nd daughter came along)
Old 10-26-2023, 02:17 PM
Off track from the thread here, but freezing only helps a bit. Much better is to heat the arm (where the bearing is to be placed) until "goot-n-hot" and then use a piece of PVC pipe shaved to just fit the end in the bearing and it goes RIGHT IN. Thanks for Vicegrip for this.
Old 10-27-2023, 02:21 AM
need for speed
cmcfaul@aol.com
This is actually my third time doing it. Its always a pain. I usually put the bub in the oven but worry I wlll get it too hot. End up beating the hell out of it with a BFH in the end. Getting the old races off is also fun.
Looking for an easier way.
Thanks,
Chris
73 911 E
89 Carrera
Old 10-27-2023, 05:17 AM
BeerBurner's Avatar
BeerBurner BeerBurner is online now
Glorified babysitter
BeerBurner
I have a press you can use if you don't mind working in my rather cluttered (at the moment) garage.
BB.
Some say "My car is a Porsche!" I say "My Porsche is a car!" and I drive the hell out of it.
'87 Porsche 944; '10 BMW 328i xDrive (her's); '98 BMW 323is (ours)
Old 10-27-2023, 09:27 AM
Heating the aluminum make a far larger deferential is size than freezing steel. Heating the hub then gently walking a race or sealed bearing out is a simple, safe method. PVC pipe works or a shop press. Out is less risky than In.
I prefer to clean the socket of dirt , ridges and burrs then heat the hub or arm. I try to hand slide fit and slide the bearing in. Using a press for hubs and the SIR tool for arms to fully seat. Less chance of damage to the new bearing. I have seen a few folks have issues with front hubs that seem to do out of adjustment over and over. A visit to the shop press to firmly seat the races has worked each time. There seems to be a better set from a press than even beating them in. Bounce back perhaps?
Old 10-27-2023, 10:37 AM
need for speed
cmcfaul@aol.com
I heated the hub with a strong heat gun for at least 30 mins and pounded the old races out. Still waiting for the new parts from Vertex. Ordered on Monday and have not arrived yet. They are usually pretty fast.
If I heat the hub in an oven. How hot should it be?
Thanks,
Chris
73 911 E
89 Carrera
Old 10-27-2023, 07:42 PM
Shifted Shifted is offline
Shifted
I have a 50 ton press and a bunch of race and bearing adapters. Also have the screw jacks for doing it with an impact, but greatly prefer the press.
Just did the bearings in a couple of cars, including pinion and output bearings in a differential. You're welcome to bring your hubs over if you want to use the press.
Chris
1987 928 S4 - Turbocharged w/ ~600 TQ/WHP, Front/Rear big brake upgrade, MegaSquirt, and a few other things.
Old 10-27-2023, 07:44 PM
Shifted
Oh, also have an ultrasonic cleaner that I like to run the parts through before assembly, and no problem putting clean parts in the oven here. I did the 928 hubs at 350 for 30 minutes. Even so, the press was needed for installation, but a screw jack style would have worked.
Chris
