Brake fluid flush on 08 cayman s - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Brake fluid flush on 08 cayman s
Old 04-05-2022, 05:25 PM
Kk1340 Kk1340 is offline
Kk1340
Default Brake fluid flush on 08 cayman s
I have a motive power system and was wondering if I can do the flush with it. So I need to anything special due to abs system. I don't want to mess anything up .any tips ,thanks
Old 04-05-2022, 05:42 PM
Dandelion's Avatar
Dandelion
Motive works fine. You'll need a tool like a iCarSoft to cycle the ABS though.
2016 GT4
2012 Cayman R
2005 Lotus Elise
1994 RX-7 R2
Old 04-06-2022, 02:26 PM
FWIW, brake fluid is pretty stable, unless its in the caliper, where its subjected to a lot of heat. I find that periodic bleeding of each caliper (say 50-60 seconds of being pushed out by the Motive) and no bubbles coming out, is all you need to do. Plus, after 3 or 4 caliper bleeds, you've effectively flushed the entire system. Unless you've inadvertently introduced air at the master cylinder, or otherwise are having weird behavior with the brakes, the ABS should be fine without cycling. I typically try to bleed calipers before each track event.
Old 04-06-2022, 03:41 PM
Remove the fluid from the reservoir first. It has the highest moisture contamination. Replace with fresh fluid before pushing it through the system.
Old 04-10-2022, 09:50 AM
Kk1340
Thanks for the tips, I feel more confident doing this now. Does not look to be to difficult. Will remove fluid from master cylinder and go slow. Thanks
