#101
Hey Mihnea, I want to thank you and your brother again for helping me get the alignment knocked out on Saturday at the track. It was a real pleasure meeting you and watching you guys work with such precision, expertise and attention to detail. The car feels great now! I hope I can return the favor sometime. A big thanks to Martin too for allowing us to borrow his garage bay as the rain poured at VIR...
Chris Robel Current: 1987 Carrera Targa 3.4 993SS cams, Smokey Silver Semi-Daily Driver 2006 Cayman S, Guards Red, #11 part time track addict (sometimes #12 or #22) X-Terra, Blue Sold: 1970 911 T coupe, Bali Blue 1982 911 SC Targa, Guards Red 1974 914 2.0, Champagne Gold 1982 BMW 528e, White and rusty.. Deceased but not forgotten: 1968 911 sunroof coupe, Black 1972 VW Super Beetle, White |
#102
No problem. I'm really glad it worked out!
Mihnea 2007 Cayman S Track Car 2004 911 GT3 2016 Cayenne S 2017 Macan S 2008 Cayenne S - Sold 2011 Boxster S - Sold 2007 Boxster S - Sold 2001 Boxster S - Sold |
#103
How do you like the SmartStrings setup -- does it allow you to find the true centerline of the vehicle, or does it work similarly to the "jackstand/string" method?
Collin M. I wear a cowboy hat. '86 951: lucky number 13...rare 6.0L edition. '06 M3: hers. |
#104
I love it. It works by setting up a rectangle around the car and measuring from that. To make sure you get a rectangle and not a parallelogram, I just measure from the distance from the hubs to the strings. What I like about it is that you can get individual toe on each wheel as opposed to total toe, which is very important in the front.
#105
Chris M. |
#106
Lasers have nothing over Ion's fetish-like fiddling fixation. You can get down to +/- a very few hundreths of a millimeter over the 18" rims. I think there may be more noise in an OE suspension than that with all the rubber. Plus, they were repeatable measurements which I think is even more important to tuning than maybe even the absolute measurement.
#107
The key distinction that is worth highlighting is what Mihnea said about having the ability to determine individual toe (at each wheel, separately), rather than total toe across the entire track width. This is the key area where toe bars (rather than the jack stand method) come in handy. Also, keep in mind that your alignment changes very dramatically throughout the length of the suspension travel. A bump in the pavement can have more of an alignment impact than the error we usually put into our static alignment in the first place.
#108
Colin is spot on on the bump(aka bumpsteer). Edit: Sorry Collin, misspelled your name. |
#109
All of the above.
Also, it depends on the shop that you use for your alignment. In the past when I got the alignment print sheet from various shops, I noticed that they didn't even bother to get it perfect. As long as it's in the "green" area on their screen, that's fine with them. I'm sure race shops put more effort into it. Some folks claim that the string method is more accurate than the laser rack method. That's probably not true, but like I said, if the technician doesn't try too hard on a laser rack, the alignment can be a lot worse than using strings in your garage.
#110
Spending an entire weekend aligning the car just so, with Ion's help, and then losing that precise alignment after a couple sessions on track has gotten a little old, so I decided to throw on some RSS locking plates for my rear toe arms. These get rid of the factory eccentric bolt, which can spin, causing minute alignment changes.
Installed. ![]() $90 for two 10.9 grade blots and four pieces of metal plate. I need to start making this junk at home...
| Thread Tools | |
| Display Modes | |
