Breaking and breaking in. - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Track Talk » Breaking and breaking in.
Old 05-20-2005, 10:46 AM
Robert Mitchell Robert Mitchell is offline
Robert Mitchell
Default Breaking and breaking in.
During the winter of 2002-2003 I had my 915 transmission rebuilt. The results were fantastic. I was able to shift into any gear at any time. In fact it was quite easy to shift from third to second just after redlining in third.
Little did I know this was a serious money $hift. It turns out the the previous engine builder used boat anchors and other salvaged parts to build my motor. This minor overrev (~8,000 RPM) caused the valves to float and bend and the left bank cam nut to come loose. Apparently the previous engine builder did not properly torque the cam nut.
Well, as it turns out there was another motor in my mechanic's shop that had been there two years awaiting a rebuild. It took him over a year to finish that motor and start on mine. Then mine took another year. Many have said that I may have too much patience
Today I got the call that my car is ready. As soon as it stops raining I will go get the car and begin the break in process. There are at least 182 pictures of the entire rebuilding process at the link below. Skip to about page 17-18 if you are only interested in the mostly assembled pictures.
http://www.tagmotorwerks.com/gallery/32911engine
2001 Boxster S
1974 911 3.2 Track Car (Deceased after contact with blue Armco)
2005 997 Grand-Am GS Spec. (The Pumpkin)
Old 05-20-2005, 12:50 PM
APKhaos's Avatar
APKhaos APKhaos is offline
APKhaos
Great news, Robert.
I was one of those who wondered when the red machine would be back on track, but figured you would be tired of people asking. My experience has been that when what should be a short project takes that long, the owner of the project is usually suffereing cruel and unusual punishment at the hands of the shop involved
The engine looks gorgeous, and I'm sure it sounds even better. Take it easy on the rod bearings for a good few sessions. Bring the max throttle opening and the max revs limit up slowly.
Tony K
PCA Potomac, Rennlist Member
89 944 Turbo
85 Carrera - Sold
TrackVision
944Cup
Old 05-20-2005, 01:14 PM
Robert Mitchell
Thanks for the kind words and the advice. I'm sure the max throttle will not be a problem but the max revs will be difficult.
After the first year, I must admit that I did get tired of people asking about when it would be ready.
2001 Boxster S
Old 05-20-2005, 02:16 PM
Now see, there it is Imagine how the rest of us felt having to keep asking, over and over... Nice photos!
I just googled “patience” and got 10 pages of hits on you address (I think at least half were really your wife’s )!
But the years have pasted and while I remember you saying the car might be too much for you then, it ought to be a good fit now! And your SO gets her own car again
Good luck and welcome to the HP wars!
How about a quick run down on the motor and car
Old 05-20-2005, 02:53 PM
Robert Mitchell
Actually, the SO is sharing this car Unfortunately for me, she had much less patience with the process.
Motor:
3.2 Liters
ITG Air Cleaners
TWM 46mm Throttle Bodies
31 lb/hr injectors
Ported heads
Crank plugs replaced with threaded plugs
New Webcams 906/Carrera 6 grind (you should hear it idle)
ARP Rod Bolts and cylinder studs
11 : 1 compression ratio
B & B Headers and muffler
Electromotive TEC 3r Engine Management System
The Car:
1974 911 no sunroof coupe
Fairly well stripped (no parking brake even) PO claims 2250lb with 1/2 tank of gas
Recaro SPG seats and 5 point harnesses
Fiberglass front and rear bumpers
Full roll cage welded into both the front and rear suspension mounts
24/31mm torsion bars F/R
22mm Weltmeister sway bars F/R
poly bushings everywhere
monoballs
turbo tie rods
custom valved Bilstein shocks
Big Reds in front and Carrera brakes in the rear
245/40-17 front, 275/40-17 rear on Fiske FM-10 (spare wheels Fiske FM-5 soon to have Toyo RA-1 mounted)
7:31 axle with stock first gear and close ratio gears 2-5 (2-3 raised from stock, 4-5 lowered so that each ratio covers about 30 mph)
2001 Boxster S
Old 05-20-2005, 07:46 PM
Sweeeeet
Old 05-21-2005, 10:35 PM
Charlie Stylianos's Avatar
Very sweet!! What cams are you running? Noticed ~7.0mm of lift in those timing pics. Thats going to be a screamer.
Kyriakos E. Stylianos
Baglama inspired
Old 05-23-2005, 10:21 AM
Robert Mitchell
The cams are a 906/Carrera 6 grind by Webcams.
2001 Boxster S
Old 05-23-2005, 12:20 PM
racer's Avatar
racer racer is offline
racer
I can smell the race gas from here
- 1970 914-6
- 2000 Boxster
- 1987 944
- 1987 924S
- 1978 911 Euro SC
- 1976 914 2.0
- 1970 914 1.7 / 2056cc
