Seat belt law in VA - Dorkiphus.net
Old 01-13-2007, 12:32 PM
jvreed jvreed is offline
jvreed
Default Seat belt law in VA
Anyone know the VA seatbelt law for harnesses? I got a Sabelt 3 point autocross belt installed in my 71 (3rd point mounted to a bar welded to the body along the firewall) and I am getting ready to go get inspected. Can I get away with that?
Thanks
Jeff
Old 01-13-2007, 01:06 PM
Rick V Rick V is offline
My wheels are blingie
Rick V
No, unless you an produce DOT paperwork for the belt, or it has the DOT tag sewn into the webbing. As for the mounting............that depends on the inspector. Sorry
82SC, Lanna
97 Boxter, She named it Willy
Go Army
Old 01-13-2007, 01:10 PM
jvreed
Thanks Rick, so if my car originally came with just a lap belt then I can just install the lap correct?
Old 01-13-2007, 01:18 PM
Rick V
That is correct, as long as it is of an approved type, and mounted in the same fassion used by the factory. You can have extra belts in the car as long as the factory stuff is there.
82SC, Lanna
Go Army
Old 01-13-2007, 04:43 PM
thomschoon's Avatar
thomschoon thomschoon is offline
thomschoon
You need to have the "FMVSS" approval on the belts which is on a tag or is engraved into the mounting tabs, that is if they even look past the simple fact that you have seat belts.
Thom
'81 SC Euro, garage queen
'02 Boxster $, stuck in depreciation cycle
'82 Crossle 50F Formula Ford
'96 Argo Formula Asia (similar to F3 but with DOHC 2 liter)
Old 01-13-2007, 09:49 PM
Thom
x2... about looking
Old 01-14-2007, 11:16 AM
racer's Avatar
racer racer is offline
racer
Um, not sure what "brand" your '71 is, but if its a Porsche it came with a 3pt belt. Not a retractible 3pt, but a 3pt nonetheless. I do find it odd that the state would say, ok, a 35 year old belt, exposed to sunlight, cold, heat, food, "oils" etc is ok, but a 3yr old aftermarket belt is cause for concern.
- 1970 914-6
- 2000 Boxster
- 1987 944
- 1987 924S
- 1978 911 Euro SC
- 1976 914 2.0
- 1970 914 1.7 / 2056cc
Old 01-14-2007, 12:00 PM
jvreed
Thanks for the info everyone. Now I need to get some old belts!
