| Professional Help Post local shops and businesses you trust and recommend. |
Hi Guys,
My clutch blew and I need to have it replaced. anyone here had theirs done recently that can provide feedback on cost and a good shop that can do the work? Damn grinch! Thanks! martin |
From what I know, there's no easy way around a 944 clutch (although I believe the 968's finally provided an access panel on the bell housing). You either pull the engine from the top, drop the suspension and engine from the bottom, or disconnect the tranny and torque tube; neither of which is particularly easy.
As far as a shop job, the cost is probably going to be around $2000-2500. However, if they remove the engine, it could be a prime opportunity to do rod bearings, timing belt, water pump and RMS. Alot of the labor could be absorbed by combining jobs. At the very least, get the RMS done, and insure you're not replacing the clutch with an OEM rubber-donut-in-the-middle variant. I've had good work done at Intersport. Ask for Charlie, and he can detail how & whether the jobs should be combined.
- Tony P. Currently - 1984 944 SP2 racer - 1977 911 KM Special vintage racer - 2000 Boxster S (now mine) - 1995 993 (garage queen) - 2007 Cayman S (wife's track beast) - 2017 F350 (tow monster) - 2018 Jeep Wrangler - 1982 911 Targa (resurrection in process) Gone but not forgotten - 1989 944S2 - 1979 RX7 - 1986 944 - 1991 944S2 (in car heaven...) - 2001 Chevy Suburban 2500 (FIL's beast now) - 2012 Cayman R Last edited by HoodPin; 12-14-2007 at 12:05 PM. Reason: Corrected my original inaccurate estimate... |
Greg Rockville MD |
Thanks Tony and Greg. Greg, do you have the contact info for Ralph's?
You can tell him I sent you (Greg Cirillo) but I only bought the car in September and used his shop once for the PPI. He may not remember me.
Greg Rockville MD |
No. Intersport Performance is in Tysons Corner. Their number is 703-242-8680. Ask for Charlie Murphy; he's one of the owners and a 944 Guru Extraordinaire. Charlie usually has simple is better approach, and I like that.
Of course they aren't the only shop in town. IMA is another good one, although I've heard that like to promote more go-fast upgrades whenever possible (Ivan is the builder of "Blue Meanie"). I was referred to Intersport by several friends, and have -0- regrets. Lots of good shops out there, including RPM, Curry's, Tag, Funktion, ASG, TPC........
Thanks Tony, called Intersport they quoted me $2300 for a clutch job.
Oh my damn. Let us know if you get any other quotes.
Greg Rockville MD |
Well
If you ask for other quotes, make sure to ask also about the RMS. I apologize for exposing my DumbAssity.
- Tony P. Currently - 1984 944 SP2 racer - 1977 911 KM Special vintage racer - 2000 Boxster S (now mine) - 1995 993 (garage queen) - 2007 Cayman S (wife's track beast) - 2017 F350 (tow monster) - 2018 Jeep Wrangler - 1982 911 Targa (resurrection in process) Gone but not forgotten - 1989 944S2 - 1979 RX7 - 1986 944 - 1991 944S2 (in car heaven...) - 2001 Chevy Suburban 2500 (FIL's beast now) - 2012 Cayman R Last edited by HoodPin; 12-15-2007 at 06:11 AM. |
