best way to remove undercoating? - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » best way to remove undercoating?
Old 12-06-2005, 12:13 PM
Default best way to remove undercoating?
where it's coming off in pieces, i just pry it off, but obviously there are areas where it's stuck. is this a chisel/hammer kind of project or a wire wheel type?
any chemicals that can help me?
Old 12-06-2005, 12:32 PM
Heat and scrape? that's what I usually hear... (assuming nothing combustible nearby)
Old 12-06-2005, 01:01 PM
William Miller's Avatar
William Miller
Are you talking about the stuff on the inside on the floors or the rubbery stuff on the outside of the tub?
On the inside stuff I found that just a little heat breaks the bond and it comes off in big chips or sheets.
The outside stuff, If not a ton. It was best to chuck up one of those hard stripping wheels in a die grinder. The one I have is dark red and looks like a really heavy duty 3m pad, but much stiffer. I used it on the front of the tub where the fenders mate and that area I needed to replace some metal. Worked pretty good because it was just flexible enough so it didn't eat thru the galvanized layer, but took the other stuff off. (The stuff on my car was a whitish/putty color).
It's a messy project. Hope you don't have a lot!
Thanks! WCM (Bill)
'81 911 SC Red Targa 3.6
'08 335i Blue Sedan
'05 Chevy Tahoe green
'98 Jeep Cherokee XJ "Blue"
'01 Toyota 4 Runner "Pearl"
Darnestown, Maryland
Old 12-06-2005, 01:15 PM
thanks guys... i'm referring to the outside stuff.... i've got a lot
Old 12-06-2005, 01:23 PM
Noah's Avatar
Noah Noah is offline
Noah has one HoF thread
Inside and outside are serious, messy, projects with a very minimal weight savings. Heat gun/scraper or wire wheel. Messy.
Old 12-06-2005, 01:32 PM
Careful - that stuff may be the only thing keeping your car from becomes a big pile of Fe02
Old 12-06-2005, 01:39 PM
Parenn911's Avatar
Loose Lips Sink Ships
Parenn911 has one HoF thread
Sat in the back seats lately?
This is a serious ass pain job. I did it when I stripped out my interior and it is the most time consuming task out of the whole process.
Old 12-06-2005, 01:45 PM
i need to address it for preventative reasons...
.......though i'd be super pissed if i went through all that and then balled it up first day next season
(yeah, i've got a twisted mind)
Old 12-06-2005, 02:21 PM
William Miller
I think that stuff is good and bad. It keeps the moisture out, but if it gets wet behind it it also holds it in too. Where mine rusted thru the coating looked great on both sides, but there was nothing but muck between the two layers. The PO had a slight fender bender, but when they installed the new fender the probably didn't seal it right.
Thanks! WCM (Bill)
'08 335i Blue Sedan
Old 12-06-2005, 02:26 PM
markwemple's Avatar
markwemple
Chemical strippers work but you'll need to use a ton and will wnt to do it ouside in warm weather. Careful with heat as there are many things, including undercoating, that like to ignite.
