| Tools Needed/For Loan If you need to borrow some tools, or have tools to loan, post here. |
For those pesky axle nuts. SnapOn 'torqueometer'. Dial indicating type. Twice as accurate as Dave's for those special jobs. AND, recently calibrated in 1987 :P
Can I barrow?
I have to do both the axle nut and the ball joint nuts. I only need it for a few minutes. These pieces are portable now. I would just need to figure out some way to hold them while tightening. Josh needs it at the same time with my ball joint nut tool.
John said its not a problem, but he also has a 250 lb/ft wrench that would be better for the ball joints.
Is there a time that works best for you? My parts are portable as well...
- Josh - '72 911T - '81 SC |
I did my rear wheel bearings recently and don't have a wrench capable of setting the axle nuts to the required torque (360 ft/lbs I beleive). Is there any chance I can borrow this tool? I understand I'm a new guy so you may be wary...
Let me know, and thanks in advance! |
Hitting that kind of torque on a loose part is going to be real hard. It might be better to install and then tighten.
Hmm, I'm not sure what you mean, the Axle nut is on the car and torqued as much as I could by hand (still nowhere near the amount needed).
I have removed the centercaps from my wheels so I should be able to torque these down without even lifting the car. Thanks though! |
It was a X-mass present from my wife. She regularly hits the “gift bull’s-eye”
I can completely understand that sentiment Dave. Thanks anyway!
Paul Caiazzo |
[quote="BlackTalon Ha! Now that Dave has lost the Santa beard, he's acting like the Grinch!
Dave, I’m the same guy, you just listen closer. Especially after I saved your a## from being compressed, and as always thanks for the uncivil engineering and math lessons . And Paul you are welcome to the wrench when ever you need it
| Soft Sockets & Lug Torque | VaSteve | Porsche Technical Discussions | 24 | 06-02-2005 03:46 PM |
| Torque and the HF Torque Wrenches | VaSteve | Porsche Technical Discussions | 17 | 12-21-2004 06:34 AM |
| $9 Torque Wrench | 914guy | Miscellaneous Discussions | 10 | 07-24-2003 05:05 PM |
| HELP! Need wrench to torque heads | rs911t | Porsche Technical Discussions | 4 | 01-06-2003 10:16 AM |
