Help! Can't separate the alternator from the housing... - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Help! Can't separate the alternator from the housing...
Old 11-06-2004, 04:48 PM
Eli's Avatar
Eli Eli is offline
Eli
Default Help! Can't separate the alternator from the housing...
Hi,
I'm in the middle of replacing the alternator in my '87. I got the fan/alternator/housing out of the car, but for the life of me cannot separate the alternator/fan from the housing....
Any ideas? Is anyone just sitting home bored looking to wrench?
'78 ROW SC
Duo
GONE, BUT NOT FORGOTTEN
<65 356><66 912><84 944><87 944><88 924S><87 911><90 911><91 911><99 996>
Old 11-06-2004, 05:03 PM
Eli's Avatar
Eli Eli is offline
Eli
Ok...dropping it carefully on a block of wood did the trick
'78 ROW SC
Duo
Old 11-06-2004, 09:36 PM
87turbolook911's Avatar
87turbolook911
Before reinstall, check to make sure you didn't crack one or two of the brushes on the regulator during the removal from the housing. Ask me how I know...
Easy to check now......but would suck to find out after reinstalling everything.
Vu
Old 11-07-2004, 12:05 AM
markwemple's Avatar
markwemple
Also, since we have all experienced this 911 phenomenon, use anti-sieze where they mate, sparingly but covering the entire surface.
Old 11-07-2004, 12:06 AM
Eli's Avatar
Eli Eli is offline
Eli
Good idea! Thanks!
'78 ROW SC
Duo
Old 11-07-2004, 07:09 PM
Also, make sure you align the neew alternator in the housing correctly or you will get another chance to remove it from the housing
Old 11-07-2004, 09:42 PM
Now Dave, how would you (we?) know that?
Old 11-07-2004, 09:46 PM
History is made up of great learning experiences and bad memories
Old 11-07-2004, 11:55 PM
Eli's Avatar
Eli Eli is offline
Eli
ok...alternator done! thanks for the tip on alignment. I did have to go back at one point. For a pretty straight forward job it sure took a long time...
'78 ROW SC
Duo
:?: Cam housing oil leak - how hard to fix MatP Porsche Technical Discussions 24 03-08-2005 12:37 PM
Looking for a used front right corner light housing 87turbolook911 Porsche Technical Discussions 8 04-16-2004 02:58 AM
