Boing! - Help with broken garage door spring - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » Boing! - Help with broken garage door spring
Old 01-31-2017, 08:04 AM
vranko's Avatar
vranko vranko is offline
vranko has one HoF thread
Default Boing! - Help with broken garage door spring
Garage door torsion spring bought the farm yesterday. Any guidance on how to repair? DYI? Hire someone? Where to buy part and how to figure out what size/strength?
Thanks,
John
John V
2024 BMW G87 ///M2 (Next 444)
2016 BMW M235
2015 Porsche Cayenne Diesel
2007 Cayman S, #444
2013 Golf R
2012 BWM x5
2017 Mazda MX-5 Club
3 time DE Parade Lap Champion
#BestInstructorEver - Unknown
Old 01-31-2017, 08:59 AM
I work on them all the time. Don't listen to the folks that make torsion springs seem like unstable explosive devices. You might find that this is not a business that has a high labor rate and you might be better off shopping the repair around a bit.
If you want to do it yourself you can go on the internetz and find sites that sell springs all ready to go and offer instructions on how to replace them. Once replaced they need to be wound and this is where many get nervous. Like many things the danger is not in doing it right but not being informed as to how to do it and following simple methods. And contrary to popular belief you can in face weld a spring back together. Weld one half coil around from the break in each direction using a 50% stitch weld. Rewind and done. I have had welded springs that have outlasted new springs cycle for cycle and when they did break it was not near the welded coils. I use welding as a temp fix only for the most part. In a house setup temp might mean 5 years additional service or a week.
The spring is measured 5* ways. 1. wire size. The diameter of the wire itself. 2. coil size. measured as an outside diameter. 3. length of the entire coil. 4* right or left hand. 5* jack shaft diameter. the size of the rod the spring is mounted on.
*Right or left and jack shaft dia only maters for finished springs. Some springs are sold raw, you install the ends the heat the wire ends red hot and bend in the hooks. I don't recommend this format if you are new to this.
How old is the setup? I ask as I tend to see springs fail one close to the other if the failure is due to high cycle numbers. If the door has been in service for 20,000 cycles you will do well to replace both springs at the same time. If the door is a year or two old in normal home use the failure might have been due to a defect in the wire or installation.
With the door pictured you would first count the number of paint spirals in the good spring and then de-tension it. With no tension the spiral you see will be a straight line painted or marked across the coil. Unbolt the 2 bolts in the middle support bracket and loosen the clamping bolts on the other end of the spring. lower the broken side down a bit and slide the bad spring off the shaft. Slide the new spring on and bolt everything back together. Mark the new spring with a line across the coils. Wind in the same number of spirals as the good side had into both springs and tighten the pinch bolts. each 360 degree turn of the spring end adds one spiral to the originally straight line. Test door and go have a satisfying beer.
Old 02-01-2017, 02:03 PM
This is what I found when my spring broke and I started searching around. Very rarely do I hire out a project and don't DIY, but in this case it was cheap enough to just pay someone to do the repair that I decided it wasn't worth my time doing the usual "read about it, watch videos, learn while you go", etc, etc.
When I had the high lift kit installed on my door I needed new springs, tracks, drums and cables. It took 4 hours for the retro fit all in, and my total bill for parts and labor was < $500.
Old 01-31-2017, 09:00 AM
N0tt0N N0tt0N is online now
Yikes! Flashback moment. Huge fight with my dad when he tried to convince my brother and I (indentured servants at the time) that the spring was really just a helper and that the pipe was a torque bar that did all the work. Sad day.
I think you can count the coils and the length (or the thickness of the wire).
Old 01-31-2017, 09:10 AM
Replaced both of my mom's when one failed a couple of years ago. Very straight forward once you source the part. Like Vice says easier to just have someone replace for you.
Old 01-31-2017, 09:27 AM
N Fotouhi's Avatar
N Fotouhi
Armatures. One motor gave up the ghost. The other was noisy, the wire through the spring had fallen off the roller, and the springs looked rough.
Called the local guys. Have two new doors, motors, and all new hardware.
Don't get the uber quiet belt driven motor if you have concerns about teens sneaking in or out.
The last spring replacements were many years ago. I think I paid about $100. Came with 10 year warranty
Nader
There are 3 sides to every story. Mine, yours, and the truth.
91 944 S2 - Mine, Sold
7? 914-6 Vintage racer - Mine
93 964 - Not mine
95 993 - Hers - Sold and will be missed
04 GT3 - ours? Doing double duties at DE, anyway
06 987 - Hers - plan to let son use for DE - My DIY
A few others
Old 01-31-2017, 09:19 AM
I talked to folks at http://ddmgaragedoors.com/springs/ga...or-springs.php , very helpful.
Old 01-31-2017, 09:25 AM
I get some of my raw springs from them. Vranko's door spring can be purchased cut to size and without ends as they are not bent hook type. End up being real cheap and the ends are not hard to remove and replace.
Old 01-31-2017, 09:41 AM
vranko's Avatar
Thanks Everyone! As soon as I heard this break I though, Dorki!
John V
2016 BMW M235
2007 Cayman S, #444
2013 Golf R
2012 BWM x5
Old 01-31-2017, 10:13 AM
Tito
86911TLCAB
have a similar problem but with the springs that are on the side of both doors...discovered they are all a particular color...so replace with the same color spring...haven't done it yet (made it work for now), but same may apply to these type also...
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
