Racing Seat Molding Foam Help - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Other Technical Discussions » Racing Seat Molding Foam Help
Old 05-30-2013, 03:45 PM
ruffyz ruffyz is offline
ruffyz
Default Racing Seat Molding Foam Help
I'm on a team with several big drivers with the seat mounted far back, so I'm looking for way to get me closer to the controls. We have the seat on sliders but even so I can't quite get the positioning correct. My cursory search on the internet has pointed me towards molding foam systems. Does anyone have any experience with using molded foam systems such as https://www.pegasusautoracing.com/foam-seat-inserts.asp. Or should I just buy a bunch of padding wrapped in nomex?
Old 05-30-2013, 04:43 PM
Potomac-Greg's Avatar
Potomac-Greg
Tough call. Those mouldable foam bags are not cheap and it's painful to think of investing in one for a single use. I've seen the pads like the ones at the go kart place. I doubt they are fire proof, but if YOU are wearing nomex, then maybe it's sufficient. Maybe find a team with three smaller driver and one goon, and switch?
Greg
Rockville MD
Old 05-30-2013, 04:54 PM
N Fotouhi's Avatar
N Fotouhi
I do not believe that most seat covers are nomex, so why wrap the pad in nomex? The question is how much padding do you need? Take a look at the back saver pads at Pegasus. They are about 3/4" thick, but are soft. The one I bought is large enough to cover the seat bottom and the lower part of the back of the seat. I also bought the other padding that has a adhesive backing. I figure one of those should work for our two car driver.
The Pegasus guys will tell you that two part stuff are for custom covering seat moudling, not what you have in mind.
Nader
There are 3 sides to every story. Mine, yours, and the truth.
91 944 S2 - Mine, Sold
7? 914-6 Vintage racer - Mine
93 964 - Not mine
95 993 - Hers - Sold and will be missed
04 GT3 - ours? Doing double duties at DE, anyway
06 987 - Hers - plan to let son use for DE - My DIY
A few others
Old 05-30-2013, 06:55 PM
ruffyz
Yeah the logistics of removing a hard molded custom seat during driver changes seemed difficult. I'll look more into the foam padding.
