Alternator replaced in 2-1/2 hours today. Bought rebuilt unit from Arlington Armature in Springfield for $250. Was quoted $1100+ for replacement by repair shop in Old Town. $850 saved in 2-1/2 hours is pretty good in my book.
The good was that everything went fairly smooth. I had replaced the unit 3 years ago so had a pretty good idea of what I was in for. The bad - fan shroud is cracked and I got some nice 2nd degree burns loosening the alternator ground while the engine was still, ah, warm. Got it all back together before dark. Started, ran, and puts out 13-1/2+ volts. Will check it again tomorrow after I drive into work. Thanks everybody for your assistance. First shot is halfway through. Second is my burn. Third shot is right at the start.
Chris 1985 Carrera Coupe (sold) 2004 V70R |
Good Job
I replaced mine the other year since the bearings were starting to fail, easier then I expected but I strained my back a little during installation. Shop that rebuilt the alternator also replaced a bad diode along with the regulator. A client of mine just had the alternator replaced on his VW by the Stealership. $500 for the Alternator plus $400 labor then tax, ouch.
John D 82 Rosewood Targa 06 MCS - "TARDIS" 11 VW TDI Sportwagen |
Nice job Chris.
Find any critters in there? Arlington Armature is good. Used them for a replacement (sourcing) a few years ago. Mine was either Marchal /Motorola or Paris-Rhone(sp) ... not a Bosch with internal voltage regulator. |
I think I will keep going back to Arlington Armature for all of my starter/alternator/motor needs.
No critters, just a nice coating of dirt.
