-   -   Tires (https://dorkiphus.net/porsche/showthread.php?t=5954)
OldTee 05-18-2005 07:39 AM
Tires
Found this on a (lawd forgive me) 928 site!
Kumho Ecsta Supra 712
Well, I have a couple weeks and about 2000 miles on the new Kumhos.
My initial reaction is WOW! Wierd tire design for the street. Built like a race tire with a real soft tread construction and STIFFFFFFFF sidewall layers. The compound used is sticky but not soft and the Tread wear is rated at 280 (we'll see how they wear). They are quiter than any tire I have ever run and the Old Buggers transmit road noise to the cabin much more than the newer cars so that's important. The quiet running extends all the way to the traction limit until the onset of breakaway where there is a slight scrub and then a small squeal in some conditions. For the last couple days I have finally had a chance to experiment with wet grip and they are amazing. I chose these tires over the RE730 because I thought the tread design was more advanced and the reviews and comments I heard were pointing to a tire that didn't give up as much dry traction to get longer life. Also, because of the sizes available specifically 225/40 and 225/45 and 225/50 for 16".
The wierdest part is the tire pressures I am running cold. I have run 40 front and 36 rear in my RE71 for a season and a half and 40 in all corners with the old phone dials and D40s. That was after much experimenting. With these new tires I started at 38 front and 36 rear mainly because I have a 5% lower profile in the front this time. The car was unmanageable and the rear was loose. I pulled the car up in my garage and could see the problem immediately. I was only using about 2/3 of the contact patch in the rear. So I started letting air out and ripping down the 4 miles of corners in my favorite canyon. I chalked the sidewalls as I went and let out air in a couple of pound increments. In the end I had 32 front and 30 rear. I have been flogging the car pretty hard and it seems to be running and handling perfectly. The tires are not rolling over at these pressures and the old palm pyrometer is telling me that the center of the contact patch is anchored.
So here's the deal: They are just awesome and they are dirt cheap. If they wear like they are rated to wear I may put them on my Audi next summer. They are available in all kinds of sizes and profiles too so they seem to be tailoring them to the tweeker. BTW I am running 225/45 ZR16 W63 on 16 x 7.5 and 245/45 ZR16 W89 on 16 x 9 Design 90 wheels. It's just a different car now!
Found it interesting!
ARF :P
Trak Ratt 05-18-2005 10:47 AM
We have a set on Linda’s Carrera track wheels and also like them a lot. 911 pressures we use as a starting point are reversed form his. Different wheel widths, tire size and car weight. Tyres SCREAM when under inflated so dial-in at the track is a little easier.
cmartin 05-18-2005 11:23 AM
Good stuff, I cant get enough tire info.
BTW - re730's chucked big time on my old 911, not a good track tire for me. es100s are decent, but dont have that much grip and are LOUD on the track. How loud? So loud that after a session a car I was following commented how loud they were.
