Whirring sound when engine is cold
The 944 has developed a fairly loud "whirring" sound that remains until the car is completely up to temperature.
My completely unknowledgeable instinct says belt noise, maybe a tension problem? I'm pretty sure that all of the belts have been replaced. Any ideas? |
I am sure the current 944 Guru will jump in here, you know, the one who loves working on 944s. Any way, from your brief description, I would guess at Torque tube rumble. I don't think you would hear improperly tensioned belts (could be serious problem).Could also be clutch related.
Dirk |
If the noise is coming from the front of the engine I would first suspect the timing/balance shaft belt tensioners or rollers unless they are relatively new. It could also be a water pump, alternator, or power steering pump that is getting tired.
| All times are GMT -4. The time now is 06:29 PM. |
