Two tech forms needed for Chesie and Potomac DEs
I have just realized that you will need two tech forms if you plan to run both the Chesapeake DE on 10/1 and the Potomac DE on 10/2-10/3.
If you have but one form presently, you will be amoebalike (formless, dude - thanks, Kurt!) on Saturday, and hurting for a form. So, be sure to make a copy beforehand. |
Go onto the PCA Potomac web site. You can download as many forms as you want. :D
i wrote to the contact person for the Zone 2 DE on fri for a tech form (Dennis Howard = RSAmerica@ (something.com) ) and he sent me the PCA Potomac tech form. don't know how that will work with the 2 different sponsoring organizations....
xerox it. Mostly they want to see it and if they need it leave the copy on Fri. Take the orig to PCA on Sat.
You guys do realize that bringing a blank tech form to the DE isn't going to help you, right? Maybe I should have been more specific and said you'll need two forms each with Section A filled out by a tech inspector, one for Chesapeake and one for Potomac's on track inspection, where Section B is filled out?
Thanks Bob.
A copy of the FILLED OUT tech form will be needed for Friday and the Original will be needed for Saturday. No Ticky, No Tracky. |
| All times are GMT -4. The time now is 08:17 PM. |
