Socket for flywheel bolts - 12mm 12 point allen, I think
Anyone have the correct socket to remove the flywheel bolts on my SC? I have access to an 8mm and a 10mm but not a 12, apparently Mercedes doesnt use a 12. I'll be hitting Sears and Home Depot friday with my fingers crossed.
Thanks! |
Chris, I didn't find one at Sears or Home Depot, so I have
the one Pelican sells. Give me a call if you'd like to borrow. |
I got a full set of triple square 12 pt metrics at autozone in Arlandria (4 mile run area). Cheap and lifetime warranty. They are inserts for a 1/2" socket.
I have one.
Thanks guys. I picked up a set at Autozone for ~$12. If they dont cut the mustard I'll be hitting one of you guys up.
Thanks again! Chris |
Chris, I think I have it as well. 1/2" drive.
Chris,
FYI: I found my flywheel bolts were installed with Red Loctite and were impossible to remove w/o prior heating. Those bolts should come out with minimal effort. If you get anytwhere close to stripping a bolt, best bet is to heat the head first. |
Thanks for the good advice guys. The $12 set from Auto zone did the trick, no heat needed, luckily. It seems the cheapo set I picked up is exactly the same tool as the Snap-on version, minus the 1/2" socket build onto it. :)
| All times are GMT -4. The time now is 12:38 PM. |
