| RoninLB |
05-31-2004 01:47 PM |
Originally Posted by Parenn911
Hi Ronin LB , what do you have in there? Can you please give us details on the engine?
The engine is a Competition Engineering machined 2.7
RS 8:5 pistons, Raceware head studs and rod bolts, 2.7RS dizzy, etc w/40k miles on it. The newer stuff is because now it's smog exempt.. PMO, E-cams, SSI, Monty, EGT & CHT 6cyl computer monitor. The plumbing is designed around a not popular full loop feed system. The pump feeds the filter. The filter feeds the left carb1. Carb1 feeds carb2 from the bumper side fuel bar fittings. Carb2 feeds the regulator. The regulator feeds the return line. The loop is very efficent for carb feed and operates with the stock high vol CIS fuel pump
All new custom electric in the engine comp. Marine oversized wires, gold plated terminals, marine fuse bar, alternate starter jump button, MSD CD box, coil, and noise suppressor.
All custom work is designed around quick trouble shooting and easy repair. It's as bullet proof as possible. The details are endless and extremely thought out.. for instance the diameter, thread pitch, and length of the stainless screws that hold items to the zinc plated metal threaded rivits in the preforated metal liner is thought out.. go figure.
thanks for the interest......
