-   -   2008 CayenneS Low Beam out (https://dorkiphus.net/porsche/showthread.php?t=41845)
Chopper Dropper 10-13-2022 01:55 PM
Drivers side low beam quit. Have replaced bulb (Xenon) twice, no luck they were cheap, also replaced the fuse. The harness looks OK from what I can see. Stumped
Dirk
cmartin 10-13-2022 02:24 PM
switch on, power at the connector?
connector clean, not green?
resistance of power wire?
resistance of ground?
Chopper Dropper 10-13-2022 02:44 PM
Will try that when dry out, all looks good visually, Not sure I can check resistance with what I have, just have a simple bulb tester.
Thanks
Dirk
joep 10-13-2022 03:52 PM
Did you check if your affected by this recall? Mine loves to "blink" whenever I come to a fast stop as the whole unit is shifting around sometimes.
https://www.motorauthority.com/news/...adlight-covers
Chopper Dropper 10-13-2022 04:11 PM
I saw the recall don't think it has anything to do with this, all seems tight and the recall s just to limit the focus adjustment up or down. Had no problem till returning from HPDC the other weekend when as leaving I was told light was out.
turbo23dog 10-13-2022 10:04 PM
Search Headlight Ballast at
https://rennlist.com/forums/cayenne-...-2003-2010-77/
There are many postings about ballast going bad as a fail for xenon headlights. After replacement, PWIS is needed to properly code the new part.
Good luck.
Chopper Dropper 10-14-2022 09:15 AM
Good luck.
Thanks Steve, will look into it today
Dirk
Chopper Dropper 10-14-2022 09:35 AM
Good luck.
Steve do you need to replace both sides at same time ?
Chopper Dropper 10-14-2022 01:45 PM
Dirk
Swapped Ballast side to side and one bad ballast, so finally know what the problem is. Without spending $500 or so per side, do I need to do both at same time and what is a reasonable replacement
Dirk
Patrick3000 10-14-2022 02:43 PM
Dirk
I don’t know anything about the quality of these.
https://www.rockauto.com/en/catalog/...+ballast,15962
