-   Porsche & BMW Cars For Sale/Wanted (https://dorkiphus.net/porsche/forumdisplay.php?f=47)
-   -   997 GT3 4.0 "Clubsport" Build 450hp @ the wheels (https://dorkiphus.net/porsche/showthread.php?t=40775)
TomChan 10-21-2020 02:43 PM
997 GT3 4.0 "Clubsport" Street & Track Car
15 Attachment(s)
For Sale: 2007 Porsche 997.1 GT3
VIN: WP0AC29937S793009
Color: Carrara White
Mileage: 62,950 (engine rebuilt to 4.0L at 59K miles, trans rebuit at 60K miles)
Price was: $115K New Price: $109K!
Up for sale is 2007 Porsche GT3 built to my expression of a 997 “4.0 Clubsport”. A fully-developed track weapon that is streetable. Starting with an ultra high performance 4.0L GT1-based Mezger engine built with 102.7mm bore x 80.4mm stroke, 13.5:1 compression ratio, custom dyno tuned to make 446whp on 93 octane/450whp on 100 octane(Original 3.6L engine made 360whp). This engine pulls very strong, it pulls equal to a 991.2 GT3RS on track. The transmission is a very well prepared G50 traditional H-pattern with Cup car 4.0:1 ring & pinion, 4.0 lightweight flywheel & clutch, and billet 40/60 LSD for maximum driving pleasure. The suspension, brakes, and body work is a culmination of the motorsports industry. In the 7 years that I have owned this car, over $100K was spent in parts alone to make this car in to what is today. Weighs 2983 lbs (original weight was 3306 lbs). The acceleration, cornering, and braking capability is exhilaration and in my opinion, as close as it gets to a Cup car from a street car. AC, defroster, and power windows are full functional. This GT3 is the grandest build project in my career. Why I am selling? It is because I have done everything that I wanted to do to this car, and then some, and I must say that I enjoy the build process more than the driving. So for me, the driving is to proof the work quality. Anyway, this car is my masterpiece and it is completed. It is time for the next owner to enjoy this masterpiece, and for me to start with a new project on a blank canvas. Clean title. Clean Carfax report. Emissions legal. Street legal.
Engine
• Factory Porsche 997 RSR 4.0 crankshaft
• Mahle Motorsports pistons with lightweight wrist pins
• Pauter billet 4340 chromoly connecting rods with ARP 625+ rod bolts
• Factory Porsche 997 RS 4.0 oil pump
• Factory Porsche 997 RS 4.0 intermediate shaft
• Factory Porsche 997 RS 4.0 fuel injectors
• Factory Porsche 997 RS 4.0 intake manifolds
• Factory Porsche 997 RS 4.0 plenum
• Cup S-spec exhaust cams
• Factory Porsche Motorsport 991.1 Cup billet underdrive pulley
• Factory Porsche Motorsport 997.2 Cup airbox
• Factory Porsche Motorsport 997.2 Cup headers with 200-cell cats
• Factory Porsche Motorsport 997.2 Cup side muffler delete pipes
• Factory Porsche 991.2 RS Titanium center muffler
• Rennline 90A durometer polyurethane engine mounts
• All three radiators replaced
• Starter, idler pulley, water pump and coolant tank replaced
• Coolant pipes welded
• COBB Accessport, custom dyno tuned 446whp on 93 octane / 450whp on 100 octane
Transmission
• Rebuild by Brian Copans in Feb 2019 at 60,498 miles
• Factory Porsche Motorsport GT3 Cup 4.0:1 ring & pinion
• Guard GT2 PRO billet limited-slip differential with 40/60 ramps
• Factory Porsche GT3RS 4.0 lightweight flywheel and clutch
• 90A durometer polyurethane transmission mount
• Demon Speed Motorsport remote clutch bleeder
• Shifter, cables, and clutch slave cylinder replaced
Suspension and Brakes
• DSC Sport controller and 3-axis accelerometer
• DSC Sport Tractive coilovers with Swift 120/180 (670/1000 in-lb)
springs
• Factory Porsche Motorsport GT3 Cup front and rear lower control arms
• TPC Racing monoball adjustable rear toe links with bumpsteer correction
• TPC Racing monoball rear upper links(aka dog bones)
• TPC Racing 5-way adjustable front sway bar
• Factory Porsche GT2 3-way adjustable rear sway bar
• Factory Porsche GT3RS front wheel carriers
• Factory Porsche GT3RS 4.0 rear wheel carriers
• Front and Rear wheel bearing replaced in 2019
• PFC Cup Challenge 380/380mm brake kit installed in June 2020, includes Endurance Option Titanium piston caps and 26mm thick PFC 11-compound pads
• PFC 665 brake fluid
• Brake Master Cylinder replaced in 2018
• Factory Porsche Motorsport 997.2 Cup electric power steering pump with dash kill switch
Safety Equipment, Data Equipment, and Interior
• Custom 4-point bolt-in rear section cage
• Front section cage is included with the car but not installed
• MOMO Lesmo One seats
• MOMO Mod 30 steering wheel with quick release hub
• Racetech Pro 6-point harnesses
• MOTEC CDL3 Dash and Data Logger integrated with CAN
• MOTEC V2 Camera integrated with CAN
• MOTEC shift light integrated with CAN
• Custom made light weight door panels with motorsport style door pulls
• Radio delete. Carpet delete. Airbag delete.
• Carbon fiber switch panel for power window and accessories
• Factory Porsche Motorsport 991 Cup pedal box
Body
• Factory Porsche Motorsport 997.2 Cup front bumper
• Factory Porsche Motorsport 997.2 Cup radiator ducting
• Factory Porsche Motorsport 997.2 Cup front splitter
• Factory Porsche Motorsport 997.2 Cup fender flares
• Factory Porsche Motorsport 991.1 Cup front dive planes
• Factory Porsche Motorsport hood pins
• Factory Porsche 997.2 GT3 Euro-spec rear bumper
• Factory Porsche 997.2 GT3 Euro-spec light weight rear crash beam
• Getty Design 997.2 GT3 Cup deck lid and wing with custom GT2 ram-air intake feeds
• Factory Porsche Motorsport 997.2 Cup wing uprights
• Factory Porsche Motorsport 997.2 Cup IMSA-spec carbon fiber gurney lip
• Factory Porsche LED Front running light and Rear tail light conversion
• Sunroof delete with Factory Porsche GT3RS roof panel
• Factory Porsche Motorsport 997.2 Cup front strut brace
Wheels & tires
• Forgeline GS1R 18x9.5 and 18x12 (997.2 Cup size wheels) with Pirelli DH 275/315 slicks
• OZ Racing 19x8.5 and 19x12 with Michelin Pilot Cup2 245/325 tires(80% tread remaining)
• MSI Racing bullet-nose wheel studs
• MSI Racing yellow Teflon-coated lug nuts
Vehicle Condition:
The engine and transmission are in excellent working condition. No leaks.
The suspension is in excellent working condition. No leaks. No play.
The body is in very good overall condition. Has small rock chips from track use. Left headlight lens is scratched.
Questions are welcomed. Please email: tchan@tpcracing.com
TomChan 10-21-2020 02:49 PM
5 Attachment(s)
More pics. Please email me if you have questions. tchan@tpcracing.com
TomChan 12-03-2020 02:38 PM
Sold.
